Parting out B16a swap
http://www.hondatwincam.com/dan/Buyme.html
Here is the link to pics of the stuff i have
HEAD b16a second gen new valve guide/seals, and OEM SPRINGS ALL 500 FIRM FOR HEAD used 500 miles BROKE A ROD no bent valves
Timing belt covers 10 each
Crank seal housing 20
Oil pump 50
Oil pickup 10
Crank pulley 20
Windage tray 5
IM bracket 5
Transmission support (2 diff ones) 15 each
Oil pan tapped for turbo 40
Oil breather 10
Water housing assembly (first gen)
Aem used cams gear (LOOK AT PIC)
Rear trans mount 10
Clutch slave cylinder rubber cover 5
rods used setup for SHOTPEENING 30
cams 1st gen 20
pistons 20
crank 50
injectors 50 (gsr injectors)
intermediate shaft 50 FIRM
NO TRANS< NO AXLES< < NO DIZZY<
Modified by nasteboyii at 11:28 PM 1/15/2005
Oil pump 50
Oil pickup 10
Crank pulley 20
Windage tray 5
IM bracket 5
Oil breather 10
Rear trans mount 10
cams 1st gen 20
pistons 20
crank 50
nasteboyii
Jan 26, 2006 11:48 AM
