B16 SIR II into 91 crx
Old Jan 11, 2005 | 06:11 AM
B16PowrdREX's Avatar
Default B16 SIR II into 91 crx
Im not nobbie and i have done about 7 swap already just wanted to kno if it will run ok
i have a b16 SIR I in my car now and im getitng an SIR II for cheap
i wanted to kno if i could run the motor obd0 (by using my dist., ecu, injectors, alt., 2 o2 sensors etc.)?
and later on when i get money together i will convert to obd1
all i really want to kno is will the engine preform good running obd0?
any help would be great
thanks for the help
-Chris-
Old Jan 11, 2005 | 06:33 AM
EP3_05's Avatar
Default Re: B16 SIR II into 91 crx (B16PowrdREX)
It will run fine as long as the distributor,injectors, ecu, and O2 sensors are OBD0 parts.
Old Jan 11, 2005 | 06:46 AM
Chronic_SMOKE's Avatar
yeah it will work fine i have a b16a2 in my crx, and its obd0
Old Jan 11, 2005 | 07:18 AM
b16std's Avatar
Default Re: (Chronic_SMOKE)
i got a b16a2 in my 89 civic ran it all obd1 , was ran obd0 ran fine like as stated as long as u got the parts for obd0 ..
Old Jan 11, 2005 | 09:36 AM
X-Static's Avatar
i didnt think you had to change the injectors? you guys sure about the injectors
Old Jan 11, 2005 | 09:45 AM
EP3_05's Avatar
Default Re: B16 SIR II into 91 crx (X-Static)
Well he can keep the saturated injectors as long as he removes the resistor box.
Stiff_Crx
Jun 18, 2010 04:43 AM
88 EF Hatch
Engine Management and Tuning
Oct 7, 2009 07:50 AM
the4g4d
Jan 13, 2007 04:18 PM
EK FLY
Jul 25, 2006 09:55 AM
ViperRedCRX
Feb 21, 2003 11:48 AM
