My home made valve adjustment tool...
Old Jan 9, 2002 | 05:19 PM
Tommy_Gunns's Avatar
Default My home made valve adjustment tool...
It's RSX blue (somebody painted it without my permission but it looks good anyways).
EDIT: Yes, I need to cut my fingernails...
[Modified by Tommy_Gunns, 8:20 PM 1/9/2002]
Old Jan 9, 2002 | 05:27 PM
done's Avatar
Default Re: My home made valve adjustment tool... (Tommy_Gunns)
hahahahahahh
Old Jan 9, 2002 | 05:41 PM
Willard's Avatar
what "was" it?
Will
-who might do the same thing
Old Jan 9, 2002 | 05:58 PM
Xian's Avatar
Default Re: My home made valve adjustment tool... (Willard)
what "was" it?
Will
looks like it "was" a box end wrench before a vise and 5lb sledge hammer got hold of it
Old Jan 9, 2002 | 06:04 PM
B2FiNiTY's Avatar
Interesting... nice work.
Old Jan 9, 2002 | 06:07 PM
tjtruong's Avatar
New User
Default Re: My home made valve adjustment tool... (B2FiNiTY)
nice .. i need to make one now.
how difficult was it to bend?
tjtruong~thinking about doing it to my craftsman tool
garagespecial
Guest
Posts: n/a
you surely do needa cut your nails, nice tool though
Old Jan 9, 2002 | 06:40 PM
GRM Scott's Avatar
25 Year Member
Default Re: My home made valve adjustment tool... (garagespecial)
heh, a socket and a screwdriver are all you need...trying to adjust the locknut while keeping the screw in place tends to be futile even with the screw, i find it's easier to take a measurement, loosen the nut and make an adjustment depending on where things need to go (use your judgement, after a few you'll know how much to do by feel), and then tighten, repeat as necessairy...requires no acrobatics, after some pratice you'll get it on the first try most of the time. Interesting tool tho, does it have a lifetime warranty?
Old Jan 9, 2002 | 06:41 PM
Default Re: My home made valve adjustment tool... (tjtruong)
Heat is the key. Heat it up and it bends easily...
Old Jan 9, 2002 | 06:56 PM
tjtruong's Avatar
New User
what did you use to heat it up?
tj
B18T3T4
Oct 2, 2008 07:48 PM
cu_jarrett
Jan 24, 2006 07:19 AM
CivicSiR
Dec 20, 2005 12:35 PM
morepoop4u
Nov 15, 2002 09:34 AM
TurboB18C1
Nov 13, 2002 11:29 PM
