*Two questions: about front lip and wheel paint???*
Old Jan 11, 2005 | 04:43 AM
AnToNy's Avatar
Default *Two questions: about front lip and wheel paint???*
Question #1: I have a stock lip for a 92-95 Civic Si/Ex that is a little rough around the edges. It had a few holes and scrapes. What I want to know is, what would be a could filler (like bondo) if I'm going to refurbish the lip or make it look new? I want to fill in the holes and add some more to the bottom of the lip(where it has been scraped), then respray it black.
Question #2: I'm redoing the white paint on my wheels and I was wondering if it would be better to bake the rim in the oven after paint??? And if so, what would be a good temperature and for how long? This is just to hold me over until actual powdercoating is done.
Any ideas would be appreciated
-Antony-
Old Jan 11, 2005 | 06:43 AM
AnToNy's Avatar
Default Re: *Two questions: about front lip and wheel paint???* (jaedaSC)
Anybody got any ideas?
Old Jan 11, 2005 | 07:41 AM
snatch's Avatar
I'm not too sure about the bondo for the lip, I guess it's worth a shot. Probably the thing of most importance to look at is if you can use it on an application such as plastic.
For the rim painting, I wouldn't bake it necessarily. I've repainted rims before, and have never baked them. We used a red automotive scuff pad you can buy at Auto Zone or Advanced Auto to sand it down. Then used wheel paint to repaint it. Worked perfect, looked awesome, and had held up for over 2 years now.
Old Jan 11, 2005 | 07:56 AM
AnToNy's Avatar
Default Re: *Two questions: about front lip and wheel paint???* (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">I'm not too sure about the bondo for the lip, I guess it's worth a shot. Probably the thing of most importance to look at is if you can use it on an application such as plastic.
For the rim painting, I wouldn't bake it necessarily. I've repainted rims before, and have never baked them. We used a red automotive scuff pad you can buy at Auto Zone or Advanced Auto to sand it down. Then used wheel paint to repaint it. Worked perfect, looked awesome, and had held up for over 2 years now.</TD></TR></TABLE>
I'm guess bondo will work I was just asking if there is a particular product I could use to fix the lip.
When I painted them I used the red scuff pad and Duplicolor wheel paint. It didn't work so I used 600 grit sandpaper, primered, painted, used 1500 paper, and repainted again and it still chipped. I was wondering if baking them would help it harden. Because that's what the problem seems to be.
Old Jan 11, 2005 | 08:16 AM
snatch's Avatar
I sure don't know of any particular product for that...
I'm suprised that it didn't work for the wheels. I did forget to say we primered 2-3 coats also. I don't know if maybe a paint shop would be able to give you some advice?
Old Jan 11, 2005 | 08:22 AM
SSExpo's Avatar
You can use Fiber Tech by Evercoat on the lip. You'll still need to do a think coat of body filler over that though, since it has fiberglass strands in it.
Old Jan 11, 2005 | 08:30 AM
Ricey McRicerton's Avatar
Default Re: (SSExpo)
If it's scraped before and you put bondo/fiberglass on it, it's going to crack/break the first time you scrape it agian.
Old Jan 11, 2005 | 08:35 AM
AnToNy's Avatar
Default Re: (Ricey McRicerton)
It came off of a friends car. But my car doesn't scrape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SSExpo &raquo;</TD></TR><TR><TD CLASS="quote">You can use Fiber Tech by Evercoat on the lip. You'll still need to do a think coat of body filler over that though, since it has fiberglass strands in it.</TD></TR></TABLE>
Where do you get this and how much will it cost. I was just looking for something at a decent price to make the lip look like new without buying a new one.
Old Jan 11, 2005 | 12:40 PM
AnToNy's Avatar
Default Re: (jaedaSC)
Anyone?
7rrivera7
Paint and Body
Aug 18, 2013 07:33 PM
91Ef4dR
Jan 6, 2009 03:14 PM
fms1day
May 8, 2007 06:44 PM
bow tie
Jan 26, 2007 02:03 PM
Full Race A6
Apr 16, 2004 10:11 AM
