Break issue on eg...any ideas?
Old Jan 10, 2005 | 11:07 PM
Chicano's Avatar
Default Break issue on eg...any ideas?
My 95 eg hatch...when I break it swerves to the left...the harder I break the harder it swerves...also when I drive straight the steering wheel has to be angled to the left...is this just an alignment problem or something else?
Old Jan 10, 2005 | 11:12 PM
GsR-Freak's Avatar
Default Re: Break issue on eg...any ideas? (skaterguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skaterguy &raquo;</TD></TR><TR><TD CLASS="quote">My 95 eg hatch...when I break it swerves to the left...the harder I break the harder it swerves...also when I drive straight the steering wheel has to be angled to the left...is this just an alignment problem or something else?</TD></TR></TABLE>
YES UR TEOs are the PROBLEM, time for alignment, any suspension modification? also can be uneven tires pressure or uneven dropped of the car. Toes are mostly likely the problem
Old Jan 11, 2005 | 12:53 AM
94_HATCH's Avatar
Its brake not break....
First check your tire pressure and make sure they are all equal. More than likely its your alignment though.
Old Jan 11, 2005 | 01:00 AM
_Cyclone_'s Avatar
Default Re: Break issue on eg...any ideas? (94_HATCH)
Pull your right front wheel before going for an alignment and check to make sure the flex line is not pinched. Visually inspect everything else while you're in there for obvious damage or problems.
Old Jan 12, 2005 | 01:42 AM
GsR-Freak's Avatar
Default Re: Break issue on eg...any ideas? (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">Pull your right front wheel before going for an alignment and check to make sure the flex line is not pinched. Visually inspect everything else while you're in there for obvious damage or problems.</TD></TR></TABLE>
what did you mean by "pull your right front wheel?"
Old Jan 12, 2005 | 05:43 AM
ironlung78's Avatar
if its not your alignment it could be your caliper hanging up..
is there excessive brake dust on that wheel?? Is the pad worn
more than the other side???
Old Jan 12, 2005 | 05:45 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Break issue on eg...any ideas? (sidesi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR-Freak &raquo;</TD></TR><TR><TD CLASS="quote">what did you mean by "pull your right front wheel?"</TD></TR></TABLE>
Take it off and look at the rubber brake line hose. Make sure its not pinched or twisted in something.
Old Jan 13, 2005 | 04:33 AM
_Cyclone_'s Avatar
Default Re: Break issue on eg...any ideas? (GsR-Freak)
Remove it.
90tegturbo
Mar 5, 2008 01:51 PM
soeurm
Jul 30, 2007 03:02 AM
Kanges
30
Dec 2, 2004 05:36 PM
katb16vo
Mar 26, 2004 09:47 AM
Mag00n
Aug 29, 2003 12:54 PM
