time for new tires... which ones do i get
Old Jan 10, 2005 | 09:58 PM
danny98r's Avatar
Default time for new tires... which ones do i get
i will be putting these on my oem rims. i currently have the oem re010 and i do like em, but i do not want to spend that much. i broke it down and its between the 195/50/15 so3's for $73 each or the falken azenis 205/50/15 for $70 each. which one would u guys prefer. which one is the better dry traction tire ??
Old Jan 10, 2005 | 10:03 PM
Bbasso's Avatar
Default Re: time for new tires... which ones do i get (danny98r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny98r &raquo;</TD></TR><TR><TD CLASS="quote">i will be putting these on my oem rims. i currently have the oem re010 and i do like em, but i do not want to spend that much. i broke it down and its between the 195/50/15 so3's for $73 each or the falken azenis 205/50/15 for $70 each. which one would u guys prefer. which one is the better dry traction tire ?? </TD></TR></TABLE>
Fior safety reasons alone I would Not get 195/50-15.
Old Jan 10, 2005 | 10:07 PM
danny98r's Avatar
Default Re: time for new tires... which ones do i get (Bbasso)
whats the problem with 195 50's?
Old Jan 10, 2005 | 10:13 PM
Bbasso's Avatar
Our caRs are to heavy for most of them.
(tires have weight ratings)
Modified by Bbasso at 7:32 AM 1/11/2005
Old Jan 10, 2005 | 10:19 PM
v t e c 2 3's Avatar
i have the azenis and i like them a lot.. haven't tried the s03's though.. when i have to get new tires, i will be getting another set of azenis..
Old Jan 10, 2005 | 11:22 PM
GRAVEDIGGER's Avatar
Default Re: time for new tires... which ones do i get (v t e c 2 3)
Azenis, hands down.
Old Jan 11, 2005 | 03:17 AM
SoCal ITR's Avatar
Default Re: time for new tires... which ones do i get (GRAVEDIGGER)
S-03's for your neck of the woods
Old Jan 11, 2005 | 06:26 AM
nsxtasy's Avatar
H-T Order of Merit
If money is a problem, and you're willing to sacrifice a little performance for a less expensive tire, I would suggest the Yokohama ES100. The ES100 costs 1.2-1.3 cents per mile. On a cost-per-mile basis, the Falken Azenis RT-215 costs about the same as the RE010, about 3.0 cents per mile; even though the purchase price is lower, it gets about 40 percent fewer miles, on average with similar usage. For additional comments about the ES100, check out this topic which is already in progress.
The S-03 is an excellent tire, and lasts a lot longer than the Falken, but the 195/50-15 size is 3.3 percent smaller than stock, so your speedometer and odometer will read 3.3 percent higher than actual.
Additional considerations: If you'll be driving in the rain much, which you probably do in New Jersey, the ES100 and S-03 are the best of these four tires in the rain, and the Falken is the worst. If you're going to take the car to autocrosses or track events, then the S-03 and the Falken are your best bets.
Interesting topic; we've never discussed it here before. Thanks for bringing it up.
Old Jan 11, 2005 | 06:44 AM
Ill's Avatar
Ill
Default Re: time for new tires... which ones do i get (nsxtasy)
Listen to Bbasso and Nsxtasy
Chris F's Avatar
I (H) Tread Threads
Edit, Azenis are Dry Traction kings, do you have snow tires I hope? This storm (Chicago) is probably coming your way. Well, it'll be rain by then.
Old Jan 11, 2005 | 06:55 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: time for new tires... which ones do i get (Chris F)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">do you have snow tires I hope? This storm (Chicago) is probably coming your way. Well, it'll be rain by then. </TD></TR></TABLE>
The precipitation we're expecting here in Chicago today and tomorrow is supposed to be rain, not snow. I wouldn't use ANY of these tires in snow. And they won't stick very well in frigid temperatures, even if the roads are dry - not as well as winter tires do.
Frigid temperatures, anyone?
Wednesday - High 51 degrees F, low 31
Thursday - High 31, low 0
Friday - High 8, low -4
Saturday - High 3, low -7
Sunday - High 2, low -5
Monday - High 13, low 13
Old Jan 11, 2005 | 07:07 AM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">The precipitation we're expecting here in Chicago today and tomorrow is supposed to be rain, not snow. </TD></TR></TABLE>
I heard that too-- but then I got 5 inches of heavy snow on my driveway this morning. I had to plow it to get out. 30-40 miles north of you.
Old Jan 11, 2005 | 07:09 AM
Chris N's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny98r &raquo;</TD></TR><TR><TD CLASS="quote">whats the problem with 195 50's?</TD></TR></TABLE>
load rating is not sufficient. That and the 195/50 s-03's track very badly, going every which way with any little bump in the road.
Old Jan 11, 2005 | 07:21 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">I heard that too-- but then I got 5 inches of heavy snow on my driveway this morning. I had to plow it to get out. 30-40 miles north of you.</TD></TR></TABLE>
Not here. All rain, with some freezing rain. That's what the forecast says for Milwaukee, too (although perhaps they are thinking it's rain when they're actually just seeing the tears of Packers fans crying ).
For other observers - I'm just north of the Chicago city limits, and Milwaukee is 90 miles north of Chicago.
Old Jan 11, 2005 | 07:27 AM
HypeR0070's Avatar
I got the Yoko AVS-ES100's after the first original set of tires. They worked really well, but not as well as the original set. I helped break them in with an autocross as well, but even after, they still didn't feel quite as grippy as the original. More importantly, they work well in the rain too. Cost for cost though, they were a bargain, tirerack.com is where i ordered from.
I wish I had the chance to try out the Azenis's, especially with autox-ing....however, but I guess that will be my next purchase depending on if I can afford to have another car and keep the Civic as the summer car... .... that sounds sad....Civic + Summer car...same sentence...ergh, that's a brain fart...
Old Jan 11, 2005 | 07:33 AM
Chris N's Avatar
5 inches.. damn. We had 1.5 inches or so... (in nbk) of awesome snowball/snowman snow. Most likely because of the rain we got this morning after the snowfall. Not the kind of snow that is easy to shovel
Chris - who was suprised to see a good amount of snow after all the reports and warnings of ice.
Old Jan 11, 2005 | 07:45 AM
Nytemare's Avatar
Default Re: time for new tires... which ones do i get (Chris N)
Do what I did, buy a beater.
My 91 DX with 142,XXX miles cost me just over $900 after tax, title, license and then it has some crappy tires. Cheap as hell to maintain and run. Plus over the past two year's I've actually SAVED money by insuring the Honda 6-7 month's a year and it's so much cheaper than my lowly GSR that I'm starting to make money versus where I woulda been. Then get some tires like me.... the BADASS National XG3000's
Balla 175/70-R 13's
With that bein said on my teg I got the Azenis which are GOD. The grip is UNBELIEVEABLE and for the price HOW can you beat them.
Old Jan 11, 2005 | 10:02 AM
AamirCWITR's Avatar
Default Re: time for new tires... which ones do i get (Nytemare)
re010 hands down....best response and feel
Old Jan 11, 2005 | 11:30 AM
danny98r's Avatar
Default Re: time for new tires... which ones do i get (AamirCWITR)
thanks guys i will be going with the azenis anyway just because i dont drive in the rain very much.
Old Jan 11, 2005 | 11:36 AM
KayOs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AamirCWITR &raquo;</TD></TR><TR><TD CLASS="quote">re010 hands down....best response and feel</TD></TR></TABLE>
I have yet to experience the Yokahama ES100 or S-03. With that said, I can only have a biased opinion in going with the RE010. Does it's job good
Old Jan 11, 2005 | 03:26 PM
seek167's Avatar
Default Re: time for new tires... which ones do i get (KayOs)
go so3
Old Jan 11, 2005 | 03:38 PM
Nytemare's Avatar
Default Re: time for new tires... which ones do i get (seek167)
Well since there will be almost no rain RT-215 Azenis for sure. If you got a beater it would make it even nicer though.
Old Jan 11, 2005 | 04:33 PM
hybrider's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">With that said, I can only have a biased opinion in going with the RE010 </TD></TR></TABLE>
Same here, they have been fabulous thus far and have been on the car since she was born, thats over 23k ! Although I've been weary driving re010's in heavy down pours with such minimal tread left.
Old Jan 11, 2005 | 05:52 PM
Opie's Avatar
I like my Azenis alot.
In my R, I Auto-X regularly, Drag race a few times a year and do HPDE's as often as possible.
With my little experience in all type's of racing except drag racing I love the Azenis.
Great grip in all seasons but winter
If you plan on driving in the snow at all you shouldn't get the Azenis. IMO they are dangerous to have on any car in the snow/slush. They do pretty well in the rain however, within limits. If you drive like an *** in the rain you put yourself at risk no matter what tire you have.
Best thing for you I think is to buy my spare Type-R wheels and do whatever you want with them
Old Jan 11, 2005 | 06:09 PM
KOALA YUMMIES's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso &raquo;</TD></TR><TR><TD CLASS="quote">Our caRs are to heavy for most of them.
(]</TD></TR></TABLE>
What are you smoking. Most of the 94-2000 integras with alloy wheels come with that size, even the heavier GS and GSR 4-doors...
