Integra is leaking!
Hey just curious that with all this rain in southern Ca have any of you guys had water getting in to your integra's? Last night I went to grab my note pad off the floor of my car and noticed that my carpet was soaked! I have'nt had a lot of time to figure out where the water is coming from due the non stop rain. When looking a little bit closer I noticed that the water was not coming in from the roof or window seals. My only thought is its coming up from the floor board! Is this possible? I really could use any thoughts and input on this one. Thanks for taking the time to read this and try to help me out.
might be coming from you sunroof. if your drain tubes are plugged, the roof area fills up and then seeps into your headliner, then drips to the side panels and eventually into back seats and carpet. Front passeger floor might be wet due to leak in heater core area.
Dont have a sun roof Like i said its coming from the floor somewhere, possibly from the wheel wells?? I am clueless!! Looked at it again today and tryed to soak up some of the water. I have no idea where it can be coming in from.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92 DA B16a »</TD></TR><TR><TD CLASS="quote">Same here
i get it by where the ecu is located (Front Passenger side)</TD></TR></TABLE>
i have the same problem just havent got around to fix it ....its in your hood cowl (2nd part under the top) its the little plastic boots that the screws go in they rot away and couse a leak
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThEOutSidEr »</TD></TR><TR><TD CLASS="quote">Dont have a sun roof Like i said its coming from the floor somewhere, possibly from the wheel wells?? I am clueless!! Looked at it again today and tryed to soak up some of the water. I have no idea where it can be coming in from. </TD></TR></TABLE>
What part of the floor is wet?
Taillights can leak, and so can the rear window squirter.
Mine ends up in the trunk/hatch area, is this due to the sunroof drains plugged?, my tail light seals seem to be okay and in good condition. Additionally, if it is the sunroof drain(s) plugged, how do I unplug it/them...
The part of the floor thats wet is by the ecu area but its not just damp theres a stream on my floor board! UHHHHHHHHH ...thanks for your help!
sorry to bump this thread a year late but
i got a 96 integra
my power antenna was loose, tightend that still leaks
i got new tails and gaskets cause my stocks were leaking water, i siliconed these sumbitches to the car, still leaks
im about to give up and take the car to a body shop and let them fix it. It leaks in the back left corner of the trunk ... i got a coupe.
i got a 96 integra
i have the same problem there was a post a few weeks ago about it, they said it had to do with the seals near the windsheild wippers and the bottom of the windsheild..u could prolly find the thread...i tried looking but im too lzy lol
Deffinently the front cowl at the bottom of the windshield a have a 94 gsr with same problem. You can order new oem factory plastic screw's and it will fix it, note it is not the top plastic cover that you first see. You pull that off and there is a smaller second cover that needs attention
thewrai6th
Feb 17, 2017 09:50 AM
