how do you oil/grese impact gun?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Treblarefils »</TD></TR><TR><TD CLASS="quote">just put a few drops of machining oil down the fitting where you connect the shop air works for me. You should do this often</TD></TR></TABLE>
Yup, everytime i use it i fill it with 7 drops.
If you havent used the impact gun for a while or first time i usually fill to the top then press the trigger, fill again, press the trigger. Then i add air and let it run for a min or so.
This should be in the GDD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Yup, everytime i use it i fill it with 7 drops.
This should be in the GDD</TD></TR></TABLE>
just fill in the hole? thats it? that easy? i'm such a noob.
put a few drops in the hole where the air goes in, then run the gun for a few seconds. i do this whenever i use the gun for the first time of the day.
oil b4 and after use if at all possible, marvel mystery oil gets a
from me.
ESPECIALLY if you live in a very humid area, IE Viatnewjersey...
Run the gun in reverse also if its reversible.
from me.ESPECIALLY if you live in a very humid area, IE Viatnewjersey...
boostedeghatch
33
May 1, 2005 06:19 PM
importboi22
May 1, 2004 11:11 PM
