Help with B-series motor mount
Old Jan 10, 2005 | 07:24 PM
Plugs's Avatar
Default Help with B-series motor mount
Will a 99-00 Si Rear "T" brackett aka motor mount work on a 97 Ls tranny in a Ek hatch? Or will I need a Ls "T" brackett aka rear mount? I have a 97 Ls tranny and a 99-00 Si rear mount.
Old Jan 10, 2005 | 07:45 PM
eK9aT10pSi's Avatar
Default Re: Help with B-series motor mount (Plugs)
to put s b-series engine in a 96-00 non-si civic, your going to need the rear si motor mount and the delsol a/c bracket if you want to keep a/c
Old Jan 10, 2005 | 09:23 PM
colinproctor's Avatar
Default Re: Help with B-series motor mount (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">to put s b-series engine in a 96-00 non-si civic, your going to need the rear si motor mount and the delsol a/c bracket if you want to keep a/c</TD></TR></TABLE>
thats not all
most of your stock mounts work except you will need the 94-97 Del Sol vtec a/c bracket and the front transmision mount will have to be changed to any of the following, 94-up Integra, 94-97 Del Sol vtec, 99-00 Civic Si. you will also need the rear 99-00 Civic Si mount bracket or CRV is the same thing. also you will have to change the mount bracket on the actual motor on the crank side to a 99-00 Civic Si.
Old Jan 11, 2005 | 04:08 AM
Plugs's Avatar
To let everyone know now. I had at B20vtec with 99-00 Si Mounts in my 97 Hatch. I blew my B16a2 tranny last friday. So I have a 97 Ls tranny as a back up. I was just checking to see if I needed Ls Tranny mounts to install the Ls Tranny.
So what you all are telling me is I can use the same 99-00 Si mounts I was using before right?
Old Jan 11, 2005 | 08:48 AM
Default Re: (Plugs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plugs &raquo;</TD></TR><TR><TD CLASS="quote">So what you all are telling me is I can use the same 99-00 Si mounts I was using before right? </TD></TR></TABLE>
yes
LS tranny is the same thing as the b16a2 tranny you were using, mount wise.
Old Jan 12, 2005 | 04:24 AM
Plugs's Avatar
Thank you very much. You just made my day. I thought I would have to have a Ls Mount.
CivHizzle
Dec 7, 2003 08:57 AM
ransack
Feb 21, 2003 07:56 PM
jcivic
Feb 11, 2003 07:56 PM
