Gen 2 integra camber kit
Old Jan 10, 2005 | 06:59 PM
dannylDAsport's Avatar
Default Gen 2 integra camber kit
what kinda camber kit are my follow DA integra drivers are using, and does it work well?
Old Jan 10, 2005 | 09:19 PM
Default Re: Gen 2 integra camber kit (dannylDAsport)
bump
Old Jan 10, 2005 | 09:24 PM
91TegLS's Avatar
Someone answer I have like -235.46° front camber lol.. but the washer trick helped the rears out quite a bit.
Old Jan 10, 2005 | 09:31 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: Gen 2 integra camber kit (91TegLS)
One thing I have to mention...
Most people think CAMBER wears out tires.
WRONG and not necessarily...
It's usually incorrect TOE-in settings.
For example, I can have maAaad JdDM uBer +3deg camber, but have the proper factory TOE settings, my tires will wear out normally with even wear.
However, there is one exception. Excessive camber (extreme, like more than 4 degrees) will and can wear out tires unevenly.
Whenever you alter your suspension, it's always recommended to get a proper alignment.
Old Jan 10, 2005 | 10:03 PM
SwedBoy2999's Avatar
Default Re: Gen 2 integra camber kit (NightRider-gsR)
Listen to NightRider-gsR, he's correct . If you are set on getting a camber kit though, Ingalls is about the best they make for us g2 folks.
Old Jan 10, 2005 | 10:05 PM
my toe looks good, but my camber is bad, front tires are dying on the inside. I need to find out whats a good easy camber kit setup. I already have ingall rear camber kit. tires getting eatten up and I hydro on freeway cuz its like almost smooth, losing traction on 1.8-2 in drop
GsR-Freak's Avatar
i just wondering if i can use both Ingalls and Omni cambers upper control arms at the same time
Old Jan 10, 2005 | 10:10 PM
Default Re: Gen 2 integra camber kit (SwedBoy2999)
which ingalls model are you talking about?
Old Jan 10, 2005 | 10:20 PM
http://www.lightningmotorsports.com/ingalls.htm
There's a list.
Old Jan 11, 2005 | 02:04 AM
In-N-Out Burger
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">my toe looks good, but my camber is bad, front tires are dying on the inside. I need to find out whats a good easy camber kit setup. I already have ingall rear camber kit. tires getting eatten up and I hydro on freeway cuz its like almost smooth, losing traction on 1.8-2 in drop</TD></TR></TABLE>
How do you know that you're toe-in settings are good? The only way you can tell for sure is if you get an alignment reading...
I've advised you already that it's usually toe-in that wears tires out and an indication that you need a proper alignment (BTW, when was the last time you did that?).
And the reason you hydro is because you're going to fast.
My opinion on that:
Stay away from the lanes nearest to the center divider (aka: carpool or nearby lane) since water tends to collect in those areas and those areas are where cars are prone to Hydroplaning.
Old Jan 12, 2005 | 01:48 AM
GsR-Freak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NightRider-gsR &raquo;</TD></TR><TR><TD CLASS="quote">
The only way you can tell for sure is if you get an alignment reading....</TD></TR></TABLE>
let me add something. Before im going to add soemthign, if i were you i will not use the words "the only way".
proper, classic, self-effience, save money, and a profession way to measuring toes is by using strings method. If you know what im talking about, then dont ask me what is string method. I use strings to measure my car's toes, and a foot long "something, buddle inside, sorry didn't know the name" to measure cambers. Run sweet, straight, and save me some money for performance parts
Old Jan 12, 2005 | 06:21 AM
nickG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dannylDAsport &raquo;</TD></TR><TR><TD CLASS="quote">what kinda camber kit are my follow DA integra drivers are using, and does it work well?</TD></TR></TABLE>
ingalls...dont use the cheap knockoff kind...search g2ic.com for some wannabes breaking and ****
hatch96y7
Oct 13, 2007 09:27 AM
dcdcdc
Jul 3, 2006 09:59 PM
E36 Guy
16
Apr 7, 2006 09:58 AM
crx1009
Apr 5, 2006 09:57 AM
Trumpster
Suspension & Brakes
Feb 2, 2005 08:14 PM
