del sol front sway bar?
Old Jan 10, 2005 | 06:43 PM
GS8HFL21's Avatar
Default del sol front sway bar?
my car is at home....i am at school. i cant get under to look at the suspension...does the del sol S have a factory front sway bar? i am 100 percent sure it dosent have a rear one...the si and vtec models did but not the S. any ideas?
Old Jan 10, 2005 | 06:58 PM
Sasebonian's Avatar
Default Re: del sol front sway bar? (GS8HFL21)
From what I remember, the Base S doesn't have any sway bars. The Si Vtec and DOHC Vtec did though. Please correct me if my info is wrong.
Old Jan 10, 2005 | 07:46 PM
GS8HFL21's Avatar
Default Re: del sol front sway bar? (Sasebonian)
do you know what will factory fit in the front then besides si and vtec model ones? i assume that i need a kit to install it..does anybody know where this can be had if there is one?
Old Jan 10, 2005 | 08:24 PM
94eg!'s Avatar
#1 Super Guy
Loved
If your not sure, go look on http://www.hondaautomotiveparts.com and enter model year trim etc. Then select "front lower arm". It will show you the swaybar & even what size it is.
Oh yeah, it comes with a 21mm sway bar.
Quick question: How come you want swaybars so bad, when you don't even know if you have them already?
Old Jan 10, 2005 | 08:40 PM
Ignitecivic's Avatar
Default Re: del sol front sway bar? (94eg!)
i have a eg cx which is like the del sol s. i installed the gsr front sway bar, but i had to use the lower part of the gsr as well cuz my stock cx didnt have those holes to mount the endlinks.
if ur delsol have those holes already, u wont need a kit for it
Old Jan 10, 2005 | 09:14 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: del sol front sway bar? (Ignitecivic)
my del sol s came with a stock front sway bar. no stock rear sway bar though.
Old Jan 10, 2005 | 09:15 PM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS8HFL21 &raquo;</TD></TR><TR><TD CLASS="quote">my car is at home....i am at school. i cant get under to look at the suspension...does the del sol S have a factory front sway bar? i am 100 percent sure it dosent have a rear one...the si and vtec models did but not the S. any ideas?</TD></TR></TABLE>
Think you answered your question in another post: https://honda-tech.com/zerothread?id=1110832
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GS8HFL21 &raquo;</TD></TR><TR><TD CLASS="quote">i know the ITR sway bar fits on my 93 del sol s with the help of the bsq kit. i cant find any where that says that a Gs-r one will or will not fit.i am semi-fimilar with suspension theory...however i cant seem to find anywhere if it will fit. the reason i am asking is my friend is getting rid of his rear sway...thanks to the good ppl at skunk 2. hell give it to be cheap...i want to get a rear sway bar and since its this cheap i was hoping that it might fit with a bsq kit as well. THANKS in advance for any input regarding the sway bar fitment.</TD></TR></TABLE>
Old Jan 10, 2005 | 09:16 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: del sol front sway bar? (AzntaggeR)
93 del sol S = no front sway
94+ del sol S = 22mm front sway
Old Jan 11, 2005 | 07:47 AM
GS8HFL21's Avatar
i didnt answer my question in another post....i was referring to the rear in one post and front in another post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">Quick question: How come you want swaybars so bad, when you don't even know if you have them already?</TD></TR></TABLE>
ive been under my car a bunch of times...enough in the back to figure out there is no bar in the back...but jsut couldnt remember seeing one in the front or not. i drove a civic before and after a rear bar install. i like the more soild controlled feel of driving a car with a sway bar in the rear....
del spool
Dec 18, 2009 07:15 PM
MiX
Dec 3, 2004 06:25 PM
phantom_sol
Apr 17, 2003 05:24 PM
BLK JDM
Jan 23, 2003 09:45 AM
topher
Apr 5, 2002 06:28 AM
