Multi-Port Problems
Old Jan 10, 2005 | 06:03 PM
nate_d's Avatar
Default Multi-Port Problems
Hey, I searched and couldnt find any useful info, so i decided to make a post. Here's my problem, I did the multi port swap on my d15b2 in my 1991 rex, i have a Pm6 ecu, hf injectors, hf dizzy, resistor box, and a d16a6 fuel rail. the car is getting fuel to the rail, but the injectos are not pulsing fuel into the chamber. please let me know if there's anything i could have done wrong, i used a 91 crx hf wiring harness, and all the wiring looks right. thanks, i need my car to go to work!
Old Jan 10, 2005 | 06:19 PM
nate_d's Avatar
Default Re: Multi-Port Problems (nate_d)
ttt
Old Jan 10, 2005 | 10:34 PM
bryse68's Avatar
use a noid light from like napa or something and plug it to the injector plug and try and start the car. if the light pulsates that means the wiring should be alright. next check your injectors, they might be stuck or frozen, try tapping them with a wrench or something to try and free them up. good luck.
Old Jan 11, 2005 | 09:11 PM
PrettyLude's Avatar
Default Re: Multi-Port Problems (bryse68)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bryse68 &raquo;</TD></TR><TR><TD CLASS="quote">use a noid light from like napa or something and plug it to the injector plug and try and start the car. if the light pulsates that means the wiring should be alright. next check your injectors, they might be stuck or frozen, try tapping them with a wrench or something to try and free them up. good luck.</TD></TR></TABLE>
Chugger
Dec 21, 2009 12:14 PM
Doc1020
Oct 30, 2005 01:57 PM
nate_d
Jan 11, 2005 09:01 AM
91hatch_on17's
Oct 6, 2003 07:47 AM
Iceycrx
10
Jan 7, 2003 11:55 AM
