dpfi to mpfi wiring question!!please help
Old Jan 10, 2005 | 05:33 PM
RapeV-8's Avatar
Default dpfi to mpfi wiring question!!please help
i have an dohc zc that is going to be swap in my 90 civic dx hb... instead of doing all the wire conversion in the engine bay can i just use an 90 civic si wire harness? i know i have to do the wiring inside the car too but i just wonder if i can use my si engine harness laying around
Old Jan 10, 2005 | 06:57 PM
jlicrx's Avatar
Default Re: dpfi to mpfi wiring question!!please help (igotcrx)
no - you need to use the DX harness and do the wiring changes to it - Si harness has 8 pin connector at firewall on driver's side, DX has 14 pin connector - they won't mate up - the DX chassis harness from ECU to firewall does not have wires in it for 2 of the injectors or 2 wires for the Cylinder Position Sensor
Old Jan 10, 2005 | 07:23 PM
RapeV-8's Avatar
got it thanx!!!! now how to take the flywheel of without spining the flywheel
Old Jan 10, 2005 | 07:31 PM
momstaxi's Avatar
Default Re: (igotcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotcrx &raquo;</TD></TR><TR><TD CLASS="quote">got it thanx!!!! now how to take the flywheel of without spining the flywheel</TD></TR></TABLE>
stick a screw driver between the block and the ring gear teeth on the flywheel.
Old Jan 10, 2005 | 07:43 PM
RapeV-8's Avatar
wouldnt it damage the flywheel? metal vs. metal?
entoy
Aug 18, 2013 04:36 PM
TweakedTT
Jul 26, 2008 08:07 PM
P h i l
Feb 1, 2005 02:52 PM
fwpguy
Oct 9, 2003 06:27 AM
qcoffey
Jun 29, 2003 07:18 PM
