Suspension & Brakes Theory, alignment, spring rates....
Question for those with camber kits
Old Jan 10, 2005 | 04:26 PM
SiR-ed8's Avatar
Default Question for those with camber kits
When i installed my progress camber kit ( 53.1002 ), i neglected to put 4 short steel spacers on each stud ( 1 per stud )
Illustration 3
As a result of this, both tires are slanting inwards. I can only guess this is so because i didn't place those spacers on studs.
The question is, overtime will my camber be adversely affected? Or just the tires alone ie wear out faster etc.?
I was told i can just go to home depot and get spacers from there. The problem is, i dont know the measurement of spacers i'm looking for. If i do go that route, will that be reliable? I don't want to cut corners here.
Thank you in advance
*note*
if you cant see picture blame it on imagestation
Old Jan 10, 2005 | 05:02 PM
suspendedHatch's Avatar
Default Re: Question for those with camber kits (SiR-ed8)
Photoshop that image so we're clear on what spacers you're talking about. I see "washer", "bushing", and "sleeve", but no "spacer".
I wouldn't drive the car w/visible positive camber.
Old Jan 10, 2005 | 05:31 PM
SiR-ed8's Avatar
Default Re: Question for those with camber kits (shaundrake)
Sorry i don't have the program nor do i know how to use it.
As you can see in illustration 3 there's a diagram of brackets and on top of that is stud. Around that same stud should be spacer.
Old Jan 12, 2005 | 09:40 AM
1bar's Avatar
You'r talking about the rear camber kit , correct?
Old Jan 12, 2005 | 03:25 PM
rotten's Avatar
I've you're talking about the rear camber, of course it is going to have more negative camber if you don't put the washers in... That is how you adjust the camber. More washers = more positive camber.
Old Jan 12, 2005 | 10:06 PM
ironcheftony's Avatar
he is speaking of the front camber kit
there is a gold ring/sleeve/spacer call it what u want, some have a slot cut out and it goes on the stud for the front camber kit
SiR-ed8, in ur case they slant inward meaning u need an alignment, you could simply fix this ur self by adjusting ur tie rods in more to make the wheel str8er
i was wondering how the gold ring/sleeve/spacer actually goes on, for example does it go into the body of the car to act like a sleeve for the stud to sit in or does it go between the body of the car and the camber kit to act like a spacer ?
can any 1 clear this up for me?
and do u really need it in there, and what happens if its not installed?
Modified by ironcheftony at 5:10 PM 1/13/2005
Old Jan 13, 2005 | 05:08 AM
.RJ's Avatar
.RJ
Default Re: (ironcheftony)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">SiR-ed8, in ur case they slant inward meaning u need an alignment, you could simply fix this ur self by adjusting ur tie rods in more to make the wheel str8er</TD></TR></TABLE>
NO!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i was wondering how the gold ring/sleeve/spacer actually goes on, for example does it go into the body of the car to act like a sleeve for the stud to sit in or does it go between the body of the car and the camber kit to act like a spacer ?
and do u really need it in there, and what happens if its not installed?</TD></TR></TABLE>
If it was not neccessary it would not be included in the kit.
Old Jan 13, 2005 | 09:23 AM
well it was late and i was not thinking further, if they are butterflying then he needs to readjust the camber kit, if the wheel points to the left or right like the steering wheel is turned then he can adjust the tie rods
how necessary is it ? your reply obviously doesnt help neither of us explaing why and where it would go then it would help
.RJ's Avatar
.RJ
butterflying? wtf does that mean?
The kit did not come with instructions?
Old Jan 13, 2005 | 09:48 AM
thats the term i and many others have called it for the wheel to have camber, if u dont get it, dont bother, stick with what u know, of all the camber kits i have installed, none of them came with instructions
Old Jan 13, 2005 | 10:41 AM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">thats the term i and many others have called it for the wheel to have camber, if u dont get it, dont bother, stick with what u know, of all the camber kits i have installed, none of them came with instructions</TD></TR></TABLE>
WTF is a camber kit for if you end up with too much negative camber after installing it incorrectly? If the parts are in the kit I'd use them. Then after it's installed you must get an alignment so the camber can be adjusted to whatever you desire.
Oh and just because you have a term for it doesn't make it right. It's called negative camber.
Old Jan 13, 2005 | 01:56 PM
the progress camber kit can only be adjusted 2 different differents, it had a set setting on it, you can either use this 1 or that , 1 is for a slight adjustment and the other adjusts alot more , i assume u use the 1 that adjusted the slightest, choosing either 1 will affect your "negative camber" try moving the stud to the other hole there for it will push the wheel outward more making less " negative camber" and making the wheel straight
all yall do is like to argue and see who is right, i still dont see yall answering how the gold ring goes on, i noe how a camber kit works i noe how to install it untill up to that ring, ive install many camber kits with and without that ring and wondered wtf is it there for and where the F it goes, they all came out fine doing what they are suppose to do
i dont care if there is a term for something u dont know and i might call it
there are terms people use for many things out there right or wrong, or just wat it is, some people understand and some dont, you dont have to correct me when i know what im talking about, try posting some helpful information instead of b/s arguing like 75% of honda-tech
what he has
example of ring on stud
Modified by ironcheftony at 5:11 PM 1/13/2005
Old Jan 22, 2005 | 02:39 AM
SiR-ed8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">the progress camber kit can only be adjusted 2 different differents, it had a set setting on it, you can either use this 1 or that , 1 is for a slight adjustment and the other adjusts alot more , i assume u use the 1 that adjusted the slightest, choosing either 1 will affect your "negative camber" try moving the stud to the other hole there for it will push the wheel outward more making less " negative camber" and making the wheel straight
what he has
Modified by ironcheftony at 5:11 PM 1/13/2005</TD></TR></TABLE>
I don't know what a butterfly is.
Anyway, I admit we installed it wrong. Vehicles lowered between 1.0-1.5, studs should be placed in hole 2 ( that's what we did ).
It should have been in hole 1 for my vehicle is lowered between 1.5-2.3 ( 2.0 ).
Later today I'll scan a picture of the assembly diagram.
Here is the DIY write up.
https://honda-tech.com/zerothread?id=920087
For those wishing to follow what we did. DO NOT neglect to place 4 short steel sleeves ( spacers ) on those studs!!!
^^^^ BIG MISTAKE
I can't blame the guys who helped me with it as they had no experience and was just trying to help a noob out.
2n-chilli
Suspension & Brakes
Apr 14, 2011 06:24 PM
FRKWOO
Apr 10, 2009 09:57 PM
crex23
Mar 25, 2003 12:26 PM
DjFreeze
Mar 23, 2003 06:50 PM
Nick
Dec 14, 2001 10:35 AM
