need oxygen sensor help
I have a 1988 Civic DX with a b16a swap in it. Both oxygen sensors are disconeccted and I have no idea where to run them to. Any help would be greatly appreciated.
The primary O2 plugs into the bung that reads the primaries from cylinder 1-4. The secondary O2 reads cylinders 2-3. The primary O2 should run to stock O2 location on the ecu. While the secondary O2 should run to plug C8 on the ecu.
Hope this helps a little. Here is the wiring conversion chart from Hasport
http://www.hasport.com/Tech/Wring/EFSi-VTEC.PDF
Hope this helps a little. Here is the wiring conversion chart from Hasporthttp://www.hasport.com/Tech/Wring/EFSi-VTEC.PDF
i found that in 10 seconds........
add this to yer favorites
https://honda-tech.com/zerothread?id=637661
allsho
Feb 19, 2007 06:12 PM
shadowstylz
13
Sep 15, 2003 10:33 PM
