Quick question about JDM ITR Headligh Wiring
Old Jan 10, 2005 | 12:16 PM
[Ennis_D]'s Avatar
Default Quick question about JDM ITR Headlight Wiring
I believe I know how to wire the headlights as far as which lights are supposed to be on when the lights are on, and which wires are to which light...please correct me if I am wrong! BTW: This is for the HID set up!
HID Lights: 5 Wires
Black: Ground (-)
Blue: Fog Light (+)
Light Green: City Light (+)
Pink: High Beam (+)
White: Low Beam (+)
On the JDM Headlights, you are supposed to wire the lights up in order for the Low Beam, and the City Light or Fog Light (not sure which one it is...closest light to the grill...inner most light from the turn signal). They arent supposed to be wired to where the Low Beam, Inner most light, Turn Signal, and Side Marker come on when the lights are turned on correct? Yes, I know flame away b/c I am not clear about this...I will deal with the flame in order to have my lights wired correctly! But anywho...yeah just let me know if I am on the right path here if you guys dont mind!
Two more things...If you guys could, post some pics of the JDM ITR HID headlights in action (clear pic of which lights are supposed to be on, cut off line, and how well they light up the road if you dont mind!) And finally, can someone confirm having to use a 90-93 DA Integra Hood Latch Cable when doing the front conversion? I have found mixed responses on this!
Sorry to ask for all this, just tryin to have good, solid, clear info for the guy at the body shop! Thanks again for the help...It means alot!
Old Jan 10, 2005 | 12:39 PM
six_speed's Avatar
~there is no particular order to wire up the lights
~only the city light/low beam are constanly on
~you'll need the da's hood latch and cable
Old Jan 10, 2005 | 12:45 PM
[Ennis_D]'s Avatar
Default Re: (Humping_dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon &raquo;</TD></TR><TR><TD CLASS="quote">~there is no particular order to wire up the lights
~you'll need the da's hood latch and cable</TD></TR></TABLE>
I didnt mean like what wires do I have to wire 1st before any, I was just asking which wires are what and which lights are constantly on...Sorry should have been clear about that! Thanks for the info anyways...Lights should be wired like the ones in this link correct?
https://honda-tech.com/zerothread?id=1109516
Anyone have a clear shot of the beam pattern, cut off line, and all that good stuff?
Old Jan 10, 2005 | 03:22 PM
six_speed's Avatar
~the jdm itr way is only the low beams/city lights are only on
~the person in the link wired the fog lights too(or bought the switch and turn it on), but the correct way is to buy a fog light button(it goes where your cruise button is) to light it up independently
Old Jan 11, 2005 | 06:50 AM
[Ennis_D]'s Avatar
Thanks for the help...Anyone have any night time pics?
G2DAB18
Feb 18, 2011 07:02 PM
dc2driver408
Aug 15, 2010 07:03 PM
Uneekpinoysk8er
Jun 27, 2004 07:48 PM
eternity0114
May 8, 2004 05:51 PM
TypeR 508
Jan 11, 2002 11:51 PM
