Attn: LS-VTEC'ers... to girdle, or not to girdle?
Old Jan 10, 2005 | 11:43 AM
VTC_CiViC's Avatar
Default Attn: LS-VTEC'ers... to girdle, or not to girdle?
Alright well I refuse to moap around about the untimley destruction of my motor, on with the questions.. I have access to at least 2 LS bottom ends and a pleathora or parts to go LS-VTEC, the one thing that scares me the most of this setup, aside from the lack of oil squirters, is the kind of torsional stress the bottom end sustains at 8500rpm+ So, are you guys finding your LSV's to be reliable with no girdle at high rpm? Or is slapping a girdle on a given to rev it out?
Keep in mind I have my entire GSR and internals (well, minus one 'slightly damaged piston' ) so I could fiesably swap over the crank, rods and a set of pistons, but I'd still be without the girdle and squirters. Any ideas about this route? From the looks of it, it's either gonna be this (GSR in B18B), a straight built LS, or a true LS-VTEC.
-to the addiciton
Old Jan 10, 2005 | 12:12 PM
willyboyK20's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (VTC_ohgodnotagain_CiViC)
what happened to the b18c.?! I just saw u made over 400hp!!!! wtf! wasn't built?
nm!!!!
i just saw the post!!!
that must suck *****.
Old Jan 10, 2005 | 12:18 PM
Gravy's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (willyboyD16)
lol love the new name!!!!
Old Jan 10, 2005 | 12:25 PM
dumpeDc2's Avatar
I'm a Jackass
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (Gravy)
you should spend your money on valve train its probley more importaint
Old Jan 10, 2005 | 12:28 PM
tommyten's Avatar
9500 rpms here...no girdle...ran the time below on my first pass at that rpm.
Old Jan 10, 2005 | 12:32 PM
Rod.'s Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (Tommy Ten)
8500 here ...no girdle
Old Jan 10, 2005 | 12:46 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tommy Ten &raquo;</TD></TR><TR><TD CLASS="quote">9500 rpms here...no girdle...ran the time below on my first pass at that rpm.</TD></TR></TABLE>
And it held up till? Still running? What rods?
Old Jan 10, 2005 | 01:05 PM
Rod.'s Avatar
^ runs good. I seen it in person, I think he is using same rods as me...Manley
Old Jan 10, 2005 | 01:41 PM
tommyten's Avatar
Yes, its about to run again (making a few upgrades )... I broke the stock diff after that pass.
I am considering raising the rev-limit a little. & yes I am using manley rods.
Its actually the first motor I have ever built.
Old Jan 10, 2005 | 01:50 PM
bogus_ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_ohgodnotagain_CiViC &raquo;</TD></TR><TR><TD CLASS="quote"> Keep in mind I have my entire GSR and internals (well, minus one 'slightly damaged piston' ) so I could fiesably swap over the crank, rods and a set of pistons, </TD></TR></TABLE>
wouldn't this then just be the same thing as a gsr?
Old Jan 10, 2005 | 01:52 PM
tommyten's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (bogus_ek)
yes, but I think hes worried that since he wont be able to use a girdle that he wont be able to safely rev it high.
Old Jan 10, 2005 | 02:49 PM
Mase's Avatar
id run no girdle. just make sure your crank is balanced properly
Old Jan 10, 2005 | 04:35 PM
Full-Race Geoff's Avatar
balance it, rev it to 10k and you still wont have a problem. dont need a girdle, but if its done PROPERLY (very rare) it will only help. It too easy to mess up a girdle install to make it worthwhile.
Old Jan 10, 2005 | 05:03 PM
GDM Z28's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (Full-Race Geoff)
**** a girdle.......i did
Old Jan 10, 2005 | 05:04 PM
Armed Ferret's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Full-Race Geoff &raquo;</TD></TR><TR><TD CLASS="quote">It too easy to mess up a girdle install to make it worthwhile.</TD></TR></TABLE>
unless you use factory ITR/GSR with their respective mains.
but yeah, what geoff said. it's tough to make it effective, and the majority of them aren't....at least not what they SHOULD be. much better to save that money for tuning. usually the cost of properly installing a girdle will be enough for 2-3 hours on the dyno.
Old Jan 10, 2005 | 06:24 PM
rondigs's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (Armed Ferret)
Why not put the LS crank in the gsr block? That would save alot of time and $.
I had a gsr girdle machined to fit the ls block (properly). I'm glad I had it done...kinda like insurance. But there are easier ways of doing things.
Old Jan 10, 2005 | 06:40 PM
Dunc's Avatar
BCICAN
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (rondigs)
Contradictory to everyone else, I would say yes to the girdle......I like peace of mind. If you think about it, it can't hurt and for a couple hundred I think it's well worth it. Do it right the first time.
Old Jan 10, 2005 | 07:36 PM
G
sh!t happens.
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (Dunc)
no girdle for me
Old Jan 10, 2005 | 07:39 PM
GDM Z28's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">no girdle for me</TD></TR></TABLE>
n u rev to.....
Old Jan 10, 2005 | 07:41 PM
Mase's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (civicflnum1)
he goes to 11,000
Old Jan 10, 2005 | 07:42 PM
vtec94civic's Avatar
no girdle here with gsr internals. no problems taking it up to 8500rpms.i actually had a girdle in my possesion when i was doing the build but when i got quotes from machine shops to properly do the switch-over it wasn't worth it. i used the money and spent it on itr valvetrain and omni valves.
Old Jan 10, 2005 | 07:46 PM
GDM Z28's Avatar
Default Re: Attn: LS-VTEC'ers... to girdle, or not to girdle? (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">he goes to 11,000</TD></TR></TABLE>
thats nuts.....
Old Jan 10, 2005 | 07:52 PM
VTC_CiViC's Avatar
Interesting stuff, I really thought I was gonna get alot of "you NEED a girdle" .. I had no idea so many people were having sucess without em'. So here's the next question, I of course already have my GSR crank and rods balanced, keep the GSR internals or go LS bottom end?
Old Jan 10, 2005 | 07:53 PM
Mase's Avatar
ls stroke is the ****...
Old Jan 10, 2005 | 07:57 PM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">ls stroke is the ****...</TD></TR></TABLE>
Yea I figured, and seeing how I hated my dead mid range with the JG + SC61 I'm sure the LS stroke will help, but, there's the idea of a lesser R/S ratio helping out the lack of a main girdle. Ehh.. this is gonna be a fun 2 weeks
