HELP_b18c swap now car won't start
i just put a jdm b18c manual into a 95 rs auto. the car turns over but won't make spark. i used the rs harness and wired vtec knock and aib to ecu. the car shows no codes. i have tried switching out the icm and the coil from the motor i took out of the car and still no spark. i have.08 volts coming out of the ecu to the yel/grn wire while i am cranking. . at the ICM i have 10.32v at the pole where the signal wire slides on with the yel/grn wire unhooked, i have 12.41v at the blk/yel, 12.42 at the wh/blu 11.45 at the blue, 12.43 at the coil inputs and 12.27 at the coil output when the key is on. any ideas? i have checked all the grounds and all the connectors to the engine harness, and checked continuity from the signal wire at the ecu to the icm.
byhalia,ms- i'm like 15 minutes south of memphis,TN.
sending the distributor back to osaka motors to swap for another. i hope that fixes it.
Coolcat55
10
May 18, 2007 07:36 PM
Bailhatch
Aug 5, 2004 10:13 AM
