Eg side maker wiring
I need help tryn to figure out how to wire up these jdm side markers..and does anyone knoe the dimension where to mount the markers also..dont want it to be off..thanks
theres 3 wires it depends on how u want them
grn/blk theylll go on whenever u use the turn signals
red/blk theyre on with the corners all the time and dont blink
dont try all three i blew 4 fuses =T
the correct way is only on when signalling - connect to the green wire at the parking lamp and a ground
On ek's there is a hole in the chassis frame that you can run the wires through, behind the fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doobiesack23 »</TD></TR><TR><TD CLASS="quote">I need help tryn to figure out how to wire up these jdm side markers..and does anyone knoe the dimension where to mount the markers also..dont want it to be off..thanks</TD></TR></TABLE>
I know of a way you can have your markers flash with the signal with the lights off, have them light up constant with the lights on, AND flash opposite the turn signal with the lights ON.
Connect the aftermarket light's positive (+) wire to the parking light positive (+) signal. Then, connect the aftermarket light's negative (-) wire to the turn signal positive (+) on the appropriate side. This is very easy and it gives you the best of both worlds. I know it works because I did it.
truckhigh
Apr 10, 2008 10:05 AM
