ECU... tapping off wires, will it screw up the ECU?
Old Jan 10, 2005 | 06:29 AM
Integraoligist's Avatar
Default ECU... tapping off wires, will it screw up the ECU?
Working on the VTEC lights so...
For the VTEC LED: Green and Yellow wire located in the 2nd harness attached to your ECU"
and
"For IAB LEDs: Locate the pink and blue wire in the 3rd wire cluster harness (farthest back) in the ECU"
I want to add an LED CLUSTER instead of just a regular 20mA LED...
and each Cluster runs at 90mA...
So, will the added current draw from each of the lights cause any problems? Should i use a transistor or a relay just in case?
all in all, the wires going to the ECU... will a 90mA current drop screw **** up?
Thanks all!
Old Jan 11, 2005 | 07:04 AM
Default Re: ECU... tapping off wires, will it screw up the ECU? (Integraoligist)
basically, will a 90mA drop in current cause any effects to the ECU?
Teg_Your_It
Jun 17, 2006 05:08 PM
hawj_boi_1
May 30, 2006 05:54 PM
b20_ed
Jul 14, 2003 10:34 AM
