99-00 civic p2e, p2t etc...
i have a 2000 civic, it has a sohc motor in it, is it certain only to use a 99-00 ecu? if i am not mistakened it is the small ecu? Also if i were to use an obd2b to obd1 conversion harness will it be easier?(getting rid of the crank angle sensor and 2nd o2 sensor codes etc...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ccivic »</TD></TR><TR><TD CLASS="quote">P2T is the stock 99-00 Si ECU. Go ahead and convert to OBDI.. Grab yourself a OBDIIb -> OBDI harness and a P28 ECU.</TD></TR></TABLE>
yup, you have a p2p ecu. yea, the p28 would be the easiest with a conversion harness. just curious, why do you want to do that to a stock motor?
surkitroller
Apr 15, 2005 05:05 AM
