Acura parts, or dealers... i need a clutch kit.
From: hittin corners so hard you can taste my rims..
i know alot of people that work at the dealer, at HT members... well, i was wondering if Acura sells a clutch kit... rather then buying each item seperatly.
cuz im not really looking to spend much, i just want to replace my clutch, and im contimplating going aftermarket replacement. (napa)
anyone buy a clutch KIT from honda latley? how much for OEM?
yeah, thats what i figured.. i'll be looking around.. keeping my options open. but i know at napa, you can get a clutch KIT... thats disk, plate, throw and piolt bearing. and for more, a reconditioned flywheel.. i might go this route, aftermarket, since its just a daily stock car.. nothing great.. so just work with it.
does anyone know if the dealer has a clutch KIT? the whole sha-bang-a-bang!
no the dealer doesent have a clutch kit ... get a exidy clutch kit they grab nice for stock applications ... pm me if you want me to order one for you (by the way oem uses exidy pressure plate)
i got my clutch kit off ebay....$152 shipped. comes with everything needed, clutch/pp/ bearing/alignment tool.... stock replacement, its a bump above stock. compared to at least $300 from the dealer.
Clutchcityonline is a great place to get Exedy clutches. If you're looking for a stock-like clutch I would go with the OEM replacement clutch from Exedy. It'll run you about $150. DEFINATELY stay away from a NAPA clutch. I got one for my MR2 awhile back and the thing was obviously rebuilt (and poorly done at that). The pressure plate was weak as hell in it and had zero clamping force. After I installed it and broke it in I could not spin the tires if I wanted to. I'm talking hold it at 7000 rpm and dumping it and it would just slip like a bitch. It was properly broken in also, I don't abuse my cars. I'd def go with the Exedy though.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridej7 »</TD></TR><TR><TD CLASS="quote">i got my clutch kit off ebay....$152 shipped. comes with everything needed, clutch/pp/ bearing/alignment tool.... stock replacement, its a bump above stock. compared to at least $300 from the dealer.
Bingo, get an exedy off ebay...cant go wrong
</TD></TR></TABLE>Bingo, get an exedy off ebay...cant go wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray »</TD></TR><TR><TD CLASS="quote">Try http://www.clutchcityonline.com</TD></TR></TABLE>
1994-01 Non-VTEC, VTEC
08-026 $169.00
shipped... hrmm.. im still thinking about napa, i put one in my civic, and i had no problems...
08-026 $169.00shipped... hrmm.. im still thinking about napa, i put one in my civic, and i had no problems...
and dont spend the money on the flywheel from them. If you are doing the clutch yourself pull your flywheel off and get it re surfaced, that way you know it will work fine when you drop it back in
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS-lownslow »</TD></TR><TR><TD CLASS="quote">just got my clutch put in today at a dealership... cost 302$ for all the parts... clutch, pressure plate, throw-out bearing... pilot bearing... </TD></TR></TABLE>
how much was it all together, labor and all?
i doubt its 302 installed... i looked it up through one of those honda parts online, and the cost is right around 310. i doubt Acura put it in for that much.
well, im leaning torwards Exedy.. i figurer around 150. give or take.. i just want a stock clutch.. nothing fancy. something durable, and reliable.
yeah, i think im going to go with a exedy clutch kit from a clutch related business on ebay. in the long run, about 120 shipped. can't beat that.
Great service ......
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phuc yiu »</TD></TR><TR><TD CLASS="quote">
how much was it all together, labor and all?</TD></TR></TABLE>
650$ for tranny
300$ for clutch and pressure plate
200$ install (friend is a mechanic there)
100$ axles and cvc joints
650$ for tranny
hondadriver
Jul 28, 2008 04:54 PM
