Torque specs on 1.6 VTec head.
Old Jan 9, 2005 | 09:35 PM
socaly4life's Avatar
Default Torque specs on 1.6 VTec head.
Does anyone know what the torque specs are when replacing a head gasket on a '94 EX?
Thanks.
Old Jan 9, 2005 | 09:41 PM
Street Ghost's Avatar
Default Re: Torque specs on 1.6 VTec head. (socaly4life)
for head bolts?
Old Jan 9, 2005 | 09:43 PM
Default Re: Torque specs on 1.6 VTec head. (_Edge.ONE)
Yes, and it's a single cam.
Old Jan 9, 2005 | 09:49 PM
EK k kay's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">6. Tighten the cylinder head bolts in two steps, working your way from the inside bolts to the outside bolts.
-Step 1: 22 lb ft
-Step 2: 53 lb ft</TD></TR></TABLE>
Taken from BauleyCivic's mini me write up
https://honda-tech.com/zerothread?id=635580
Old Jan 9, 2005 | 09:51 PM
Default Re: Torque specs on 1.6 VTec head. (chowmien)
Thank you very much. I'll hit you back once I'm done.
Old Jan 9, 2005 | 09:56 PM
.BigSexy's Avatar
most hood white kid
tighten them in the sequence in the haynes or helms manual to about 23 lbs. then go back throught the same sequence and tighten them to 54 lbs.
Old Jan 9, 2005 | 10:22 PM
skunk2finatic's Avatar
if you don't want it too leak, 23ft lbs , then 65ft lbs
Old Jan 9, 2005 | 10:39 PM
.BigSexy's Avatar
most hood white kid
Default Re: Torque specs on 1.6 VTec head. (skunk2finatic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2finatic &raquo;</TD></TR><TR><TD CLASS="quote">if you don't want it too leak, 23ft lbs , then 65ft lbs
if you do this and when you break a headbolt, or when you warp the head, you are gonna wish you hadnt listened to this guy
Old Jan 9, 2005 | 10:44 PM
_Cyclone_'s Avatar
Default Re: Torque specs on 1.6 VTec head. (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">tighten them in the sequence in the haynes or helms manual</TD></TR></TABLE>
Indeed, stick to specs, don't overtighten the bolts because it won't leak if you tighten them to spec.
Old Jan 9, 2005 | 10:52 PM
.BigSexy's Avatar
most hood white kid
Default Re: Torque specs on 1.6 VTec head. (CycloneBlue_1.6EL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CycloneBlue_1.6EL &raquo;</TD></TR><TR><TD CLASS="quote">
Indeed, stick to specs, don't overtighten the bolts because it won't leak if you tighten them to spec.</TD></TR></TABLE>
indeed
lintegras
14
Jan 6, 2025 07:48 PM
brainglow
Dec 17, 2007 09:57 PM
2SLO
Apr 14, 2006 07:31 PM
BrightRedOne
Oct 24, 2004 09:45 AM
G-reX
Oct 6, 2003 04:55 PM
