Power steering lines??? HELP!!!
Old Jan 9, 2005 | 08:58 PM
pubestripe's Avatar
Default Power steering lines??? HELP!!!
alright, i am pulling my ac for my turbo setup and i was under the impression that what is in the picture was for ac, but it seems to be power steering fluid coolant coils...er something... can i take them out? or do i need these for power steering?
also, if i eliminate my power steering, what else do i need to do to the steering to make it durable for not having the ps running it? thanks and here are the pics...
o and these are off my 92 gsr...
Old Jan 9, 2005 | 09:51 PM
pubestripe's Avatar
Default Re: Power steering lines??? HELP!!! (pubestripe)
anyone? sorry for the impatience but i need to know!!!!
Old Jan 10, 2005 | 01:52 AM
rovigian's Avatar
That is part of the power steering, just leave it. All of the AC parts are interconnected.
Old Jan 10, 2005 | 05:59 AM
MikeTV
Guest
Posts: n/a
buy padawan's power steering removal kit for 60 $. Worth every penny. the car will handle better and it also bumps you up 3-5 hp
Old Jan 10, 2005 | 09:11 AM
pubestripe's Avatar
Default Re: Power steering lines??? HELP!!! (Eclipse spanker)
what does that kit do??? and if i purchase it i wont have to deal with those damn coils in front?
Old Jan 10, 2005 | 11:41 AM
jonsteR's Avatar
that ps kit is made for a DC. Most of the DA guys just remove the lines (4) on the PS rack and cap it.
Old Jan 10, 2005 | 12:24 PM
pubestripe's Avatar
Default Re: Power steering lines??? HELP!!! (jonsteR)
so if u remove those does the ps still work as good as it did before? my f'ing fmic is gonna be in the way if i dont get rid of those lines in front, so i dont know what to do...
Old Jan 10, 2005 | 12:35 PM
Ballade's Avatar
use a 88-91 Streering rack. Bolt right in. even uses then same tie rod ends.
Old Jan 10, 2005 | 02:12 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote">so if u remove those does the ps still work as good as it did before? my f'ing fmic is gonna be in the way if i dont get rid of those lines in front, so i dont know what to do...</TD></TR></TABLE>
If you remove the hard metal cooler and use a quality "U" fitting to connect the two remaining hoses, you shouldn't have a problem. Certain Honda models don't even have the cooler, so I don't think PS fluid temps will be an issue.
Old Jan 10, 2005 | 06:56 PM
pubestripe's Avatar
Default Re: Power steering lines??? HELP!!! (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
If you remove the hard metal cooler and use a quality "U" fitting to connect the two remaining hoses, you shouldn't have a problem. Certain Honda models don't even have the cooler, so I don't think PS fluid temps will be an issue. </TD></TR></TABLE>
that is what i was thinking, because i dont really think that the temps of the ps fluid would be bad, and i know for a fact that my friend's 92 GS doesnt have them, so iono... u think i would be fine taking out the cooler and just connecting the 2 lines with a U joint?
o and thanks for all the replies!
Old Jan 11, 2005 | 03:17 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pubestripe &raquo;</TD></TR><TR><TD CLASS="quote"> u think i would be fine taking out the cooler and just connecting the 2 lines with a U joint? </TD></TR></TABLE>
Yes, as I said, you shouldn't run into any problems. Just use a quality fitting and clamps and you'll be all set.
Old Jan 11, 2005 | 08:37 PM
pubestripe's Avatar
alright thanks, that is what i am going to be doing then...
Old Jan 23, 2005 | 02:20 PM
pubestripe's Avatar
ok, to bring this topic back up, can i just solder on a u fitting made out of copper to bypass that cooling line?
Old Jan 23, 2005 | 02:43 PM
Padawan's Avatar
Darth ModerVader
The cooler should attach to two rubber hoses. Using a barbed "U" fitting with clamps to loop these two rubber hoses should work fine.
Old Jan 23, 2005 | 03:33 PM
pubestripe's Avatar
ok, i think ill do that then, that is a lot easier than soldering on a new fitting...lol
DAcraze
Jan 11, 2020 04:06 PM
Manolo
Jul 31, 2007 06:11 PM
hyperazn108
May 14, 2004 09:49 PM
niteboyzzz
Aug 26, 2002 06:17 PM
