yes or no to this turbo kit
i'm in the market for my first turbo kit. i found this on at camp1320.com
i'm running a 92 civic hb with a b16a.
it is my daily driver but i will be drag racing it.
any comments are appreciated.
Rev Hard Turbo KIT NEW
STAGE 2 kit w/ intercooler for Street / Track use.
Boost Level: 7psi
Injector Size: Stock
Horsepower/Torque: +120 / 285 ft/lbs
INCLUDES:
Rev Hard Cast Iron Manifold
High Volume Fuel Pump
Rev Hard T3/T04E Hybrid Turbo(eff. to 450hp)
Silicone Hoses & Clamps
Rev Hard Intercooler 27"x 6.5" x3 "
Steel Braided -3 Oil Line
35mm external wastegate (7psi)
Oil Return Line
Vortech Blow Off Valve
High Pressure Fuel Line
2.25" Aluminized Mandrel Bent Piping
High Pressure Silicon Hose
2.5" Downpipe
Necessary Vacuum Tee's
Check Valves
Necessary Vacuum Lines
Applications:> for B,D,H,K,S2000,IS300
starting @ $2649.95 shipped
Modified by jbscivichb92 at 6:02 PM 1/9/2005
Boost Level: 7psi
INCLUDES:
Oil Return Line
2.5" Downpipe
Check Valves
that is a decent option but if you didnt already know you can piece together a kit pretty cheap i am spending about the same as that kit and i have hondata s200b with datalogging and 3 step, tial wastegate and injectors plus all the things on that list..most of my stuff is new (at least the important stuff) i dont know how much experience you have but you definately need to have a source of fuel management..the better management system the more reliable your setup *should* be...thats all i got to say get it tuned. oh what i was getting to is that i dont think that kit offers a fuel management unit.
i would like to piece together a kit but i have no experience with fi. as far as engine management i was considering aem. speedfab in jax, fl is good with tuning aem but they don't do hondata. the closest place to tune hondata is in tampa.
i will probibly end up pieceing together a kit.
yeah man if you are willing to piece together a kit honda-tech will be your friend just search it up..if you can spend the money on aem i have heard its awesome...i couldnt afford it and my tuner is more comfortable with hondata so i chose that..but good luck if you need help my aim is chris dornon13 id be happy to help
get this one if you're looking for a great kit for under 3 Gs
https://honda-tech.com/zerothread?id=1077122
Fishcat37
Sep 12, 2004 08:35 PM
bread
Jul 11, 2004 08:05 PM
