D series bolts fitting in b18c1
Old Jan 9, 2005 | 03:54 PM
lazynok's Avatar
Default D series bolts fitting in b18c1
i'm missing the bolts that hold the transmission and block togehter.. can i use the bolts off my d16y7/z6?
also the starter bolts
and the mount bolts. im sure the mount bolts will work though.
thanks you
Old Jan 9, 2005 | 05:12 PM
markaria's Avatar
Default Re: D series bolts fitting in b18c1 (lazynok)
I have used d series bolts to bolt a b series to an engine stand, but I am unsure if they would be the proper length to hold the block/tranny together.
Old Jan 9, 2005 | 05:59 PM
civic-4-ges's Avatar
Default Re: D series bolts fitting in b18c1 (markaria)
Probably very close to or exactly the same bolt. Compare part #'s on SLhonda.com or Hondaautomotiveparts.com
Slacker93eg
Transmission & Drivetrain
Aug 13, 2012 05:48 AM
94Eg_SnatchBack
Apr 11, 2012 10:51 AM
jweeks
Apr 16, 2007 06:39 AM
RobbieG35
Jul 12, 2006 09:41 AM
