lsvtec oil leaking bad! from headgasket??
Old Jan 9, 2005 | 03:09 PM
hybridpatient95's Avatar
Default lsvtec oil leaking bad! from headgasket??
a friend just got his ls vtec setup put together he has a 93 ls block with a 00 si head. he bought a new 93 ls headgasket and there is still oil leaking from the head. we took out the dowel pins and it still leaks. can any one tell me what might be the problem with this setup?? the oil feed for the si head is clogged and the new oil feed doesnt leak at all. its coming from another source. can anyone tell me what source or atleast what source they think it might be?? thanks alot guys!!!
Old Jan 9, 2005 | 03:19 PM
NJIN BUILDR's Avatar
Default Re: lsvtec oil leaking bad! from headgasket?? (frankenfiend 04)
Check the rivets that hold the layers of the head gasket together.Sometimes one will end up between the head and block holding the head up.You can take them off the gasket if they hit.
Glenn
Old Jan 9, 2005 | 04:40 PM
hOndafienD 04's Avatar
they arent hitting....i checked already...and the copper thingies stick out the motor clearning both the head and the block...any more ideas?
Old Jan 9, 2005 | 05:32 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (hOndafienD 04)
anyone know???
Old Jan 9, 2005 | 06:27 PM
Targa4Life's Avatar
Default Re: (turbofienD 04)
I have the exact same problem with my LS/VTEC. I would like to know myself.
Old Jan 9, 2005 | 08:09 PM
acy76's Avatar
Default Re: (Targa4Life)
Headgaskets installed upside-down have been known to cause these sorts of leaks...
Old Jan 9, 2005 | 08:14 PM
drdisco69's Avatar
I had this problem on an LS-VTEC I did, and from what I can figure out, the fitting for the feed line in the head wasn't threaded in enough, and oil was leaking there. I didn't get enough time to fix it, I put the LS head back on. Since the head uses a different thread size than most stuff you get, there's a chance that the fitting isn't threading in far enough. In my case, it was like 3 turns...
Old Jan 9, 2005 | 08:55 PM
aero97's Avatar
is there an oil feed in the block that needs to be pluged?is the head plugged properly?
Old Jan 9, 2005 | 11:24 PM
backdraft's Avatar
How much oil is leaking????
I am pretty sure that you need the dowels to line up the head properly and so it doesn't move around and leak where it shouldn't. Next, I would check to make sure that it is not a leak from the Vtec solenoid or the distributor O-ring. Then try the vavle cover gasket and cam plug on the distibutor side on the exhaust cam. Then I would've tried the oil plug on the bottom of the Si head. Then replace the head gasket after all of these things were ok. Try what I suggested and hopefully it will fix your problem. Good luck.
Old Jan 10, 2005 | 09:43 AM
we checked all the things you suggested and the head gasket is brand new! we ran it with dowel pins....it leaks....ran it w/o dowels.....it leaks (not as much) we ran the car for about and house yesterday and it seems to lessen a bit....so we'll see what happens today...what are we supposed to plug on the head?
Old Jan 10, 2005 | 11:05 AM
backdraft's Avatar
There is a little hole that is used to activate the vtec on a regular vtec motor. You need to plug that hole otherwise it will leak. It is on the underside of the head on the distibutor side. What head bolts or studs are you using???? Does it run OK besides the oil leak?? And again, How much oil?
Old Jan 10, 2005 | 11:44 AM
Default Re: (backdraft)
were using b16 head bolts. it performs good but vtec doesnt work. sometimes it does then sometimes it doesnt. but other than that it doesnt leak that much oil no more. now its a overheating problem...
Old Jan 10, 2005 | 03:28 PM
b16 head bolts....it performs like a champ....we are running ls ecu so no vtec yet....it only has the overheating problem, but that can be solved easily and now the slight oil leak....
Old Jan 11, 2005 | 11:44 AM
bump!
Old Jan 28, 2005 | 11:54 AM
99lsvtecauto's Avatar
Default Re: (frankenfiend 04)
wrong head bolts b16 are 2 short u need gsr head bolts or studs
Old Jan 28, 2005 | 05:39 PM
k24a4kid's Avatar
I'm a Jackass
Default Re: (99lsvtecauto)
it's fixed, it was coming from the plug in the head
Old Jan 30, 2005 | 08:21 AM
the plug thats in the back
eksleeper97
Engine Machining & Assembly
May 15, 2016 01:48 PM
NOTDISFA5
Aug 8, 2010 08:02 PM
stadanko
Jul 21, 2009 04:08 PM
CRXGSR
Mar 11, 2003 09:28 PM
lsvtecvx
Dec 7, 2002 02:37 AM
