what all swaps from a da??????
Old Jan 9, 2005 | 02:42 PM
Mikey361's Avatar
Default what all swaps from a da??????
like the topic says . i got a 91 gs teggie that i bouth for like 200 bucks . after leting it sit in the garage for a few months im starting to wonder what all will swap , other than the motor(duh). mainly brakes and susp. wise? ive always like the 88-91 civic si' and have a few to pick from. the teg runs strong and all just not geting off to the body style'n all to much any more. any help, pics, links , or anything will be put to good use . i wanna build a car for auto x but that can still hold its own at the strip. thanks
Old Jan 9, 2005 | 03:28 PM
mrspeaker's Avatar
Default Re: what all swaps from a da?????? (mle_92cx)
Suspension and brakes bolt up..
Mod these things to fit..
Drivetrain
gauge Cluster
Lip
Front and rear seats
center console
steering wheel..
Old Jan 9, 2005 | 05:23 PM
bagpipe goatee's Avatar
the front spindles dont work unless you want terrible camber, otherwise he's right. when you switch the brakes, you wanna switch the mastercylinder/booster/prop. valve
Old Jan 9, 2005 | 05:55 PM
Stefndogg's Avatar
Default Re: (bagpipe goatee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bagpipe goatee &raquo;</TD></TR><TR><TD CLASS="quote">the front spindles dont work unless you want terrible camber, otherwise he's right. when you switch the brakes, you wanna switch the mastercylinder/booster/prop. valve</TD></TR></TABLE>
wrong the front spindals work fine as long as u use the crx upper control arm
Old Jan 11, 2005 | 06:31 AM
Mikey361's Avatar
Default Re: (Stefndogg)
so everything suspension/brake wise bolts up no mods ness.?
JustHere4ADay
19
Jan 24, 2008 05:22 PM
zccr-xsi
Jul 27, 2007 06:36 AM
msinsky14
12
Jun 27, 2007 07:29 PM
BigGreenAuto
Nov 20, 2006 10:08 PM
DieMaster
Dec 16, 2004 09:35 PM
