Koni Yellow Question
Old Jan 9, 2005 | 01:50 PM
99hatch's Avatar
Default Koni Yellow Question
OK so I have had my koni yellow/ hr sport setup on for a while. The perch for the shock is set on the middle groove. Does anyone here have theirs on the lowest groove? If so do you run into any problems on the road with clearance, etc? Also post pics if you got em. TYIA
Old Jan 9, 2005 | 05:05 PM
99hatch's Avatar
Default Re: Koni Yellow Question (99hatch)
up
Old Jan 16, 2005 | 02:17 AM
Xsi's Avatar
Xsi
I think the lowest groove is for coilover sleeves to give you a bigger range of adjustment while the other grooves are just for lowering springs
I have my coilovers set on the bottom groove but I think if you had lowering springs on there it would be far too low
Old Jan 16, 2005 | 02:26 AM
GrossmeisterB's Avatar
Default Re: (Xsi)
How much lower than "stock" is your lowest groove?
do you have pics of your car with H&R springs and these konis??
I have some yellow konis as well, but I have Integra springs, and I'm wondering how much lower the H&R springs will be..
thanks man!
Old Jan 16, 2005 | 07:16 AM
99hatch's Avatar
Default Re: (GrossmeisterB)
Shes a little dirty but thats what koni yellows and H&R Sports did to my car while on the middle perch.
Old Jan 18, 2005 | 08:26 AM
Default Re: (99hatch)
Yeah, thanks for that pic...
I have another question for you, 99hatch...
My konis have 2 "grooves" in the front, one is as high as stock, the other is a bit more than 1inch lower...in the back I have 3 grooves, on "stock" one, and one higher and one lower, each about 0,6inches...so, on what grooves are your shocks?? in the "normal" groove?!?!giving it the same height than with stock shocks?
thanks for your help man!
Old Jan 18, 2005 | 08:33 AM
TheNasty0ne's Avatar
Reminds me of my old hatch.....
Old Jan 18, 2005 | 08:37 AM
Leb_CRX's Avatar
Default Re: (OoBryan)
here's mine on normal (same setup), koni yellows with H&R sports
http://www.adaccache.com/ek/ek.jpg
http://www.adaccache.com/ek/ekk.jpg
http://www.adaccache.com/ek/1.jpg
I really dont like that setup, too high and too soft
Old Jan 18, 2005 | 08:46 AM
99hatch's Avatar
Default Re: (Leb_CRX)
yours looks higher than mine for some reason
Old Jan 18, 2005 | 08:51 AM
Leb_CRX's Avatar
ya you're right, big diff
Old Jan 18, 2005 | 09:20 AM
99hatch's Avatar
all mine are in the middle, so there are slots above and below each of the perches, that is what i was trying to figure out...what it looked like on the lowest perch
Old Jan 18, 2005 | 09:23 AM
Leb_CRX's Avatar
my bad I misunderstood
reading comprehension > me
Old Jan 18, 2005 | 09:30 AM
99hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leb_CRX &raquo;</TD></TR><TR><TD CLASS="quote">my bad I misunderstood
reading comprehension &gt; me
no i was just answering the other guys question
Old Jan 18, 2005 | 11:25 AM
94eg!'s Avatar
#1 Super Guy
Loved
I read in another thread that CRX Lee (local koni rep) didn't recomend lowering the pearch in combonation w/ lowering springs. If you do, your spring rate may be too soft for such a low ride height. This will cause you to bottom out much more frequently, and possibly damage your shocks.
The lower perch is for coil over sleeves (since any spring rate can be used), or OEM springs (for slight lowering).
The upper perchs are used to raise your car if: your lowering springs are too low, you have a MONSTER sound system, or wish to load the car down w/ cargo.
Old Jan 18, 2005 | 12:35 PM
99hatch's Avatar
Default Re: (94eg!)
thanks dude thats exactly what i needed to know
Old Jan 18, 2005 | 12:41 PM
Tad's Avatar
Tad
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">I read in another thread that CRX Lee (local koni rep) didn't recomend lowering the pearch in combonation w/ lowering springs. If you do, your spring rate may be too soft for such a low ride height. This will cause you to bottom out much more frequently, and possibly damage your shocks.
The upper perchs are used to raise your car if: your lowering springs are too low, you have a MONSTER sound system, or wish to load the car down w/ cargo.</TD></TR></TABLE>
yeah thats what I would think
most lowering springs are progressively wound, in that they get stiffer the further they compress. So the beginning of compression is actually the softest part.
so if you lower that perch, the springs might bottom out before they ever even get to that stiffer portion(or at least not have as much stiff portion anymore).
Not to mention that beginning portion is softer so they'll bottom out quicker.
Old Jan 18, 2005 | 12:54 PM
99hatch's Avatar
Default Re: (Tad)
cool, i guess ill leave the perch open for if i ever get coil overs
Old Jan 18, 2005 | 01:10 PM
Daniel san's Avatar
I had my eibach springs on the lowest perch and i had CRAZY rubbing problems.
I had to take it apart to set it up higher (what a bitch)
I don`t know what my offset is, but I had 205/55/15 and it was horible. could not drive the car.
Old Jan 18, 2005 | 01:12 PM
dantastic's Avatar
sorry to thread jack, but how many perches are there front and rear? 2 front and 3 rear? just want to make sure. TIA
Old Jan 18, 2005 | 01:17 PM
Daniel san's Avatar
Default Re: Koni Yellow Question (dantastic)
Neuspeed Koni`s have 5 perches, Front and Rear, 3rd (middle one) is stock height
Old Jan 18, 2005 | 01:53 PM
94eg!'s Avatar
#1 Super Guy
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic &raquo;</TD></TR><TR><TD CLASS="quote">sorry to thread jack, but how many perches are there front and rear? 2 front and 3 rear?</TD></TR></TABLE>
Correct! This applies to standard "Koni Sports" for civics & integras. Other applications will be different.
Old Jan 18, 2005 | 03:40 PM
rafael_dias's Avatar
so if you have lowering springs and koni yellow shocks, how low do you reckon i should go? i have 15" slipstreams on 195/55s and theres about a 2 finger between the front and rear guards.. i want them to tuck a little.. what would you guys recommend? my car is lowered approx 2.5"
itr1244
Nov 7, 2015 08:42 AM
jonnybadboi9
Sep 16, 2010 02:56 AM
jonnybadboi9
Suspension & Brakes
Feb 9, 2010 08:25 PM
guero2craze
Jan 13, 2007 10:12 PM
NateTEG95
Mar 29, 2003 01:32 PM
