Question about running different fuels. i.e. 93 octane to c16
You guys out there who are running cells, or even stock gas tanks I guess. What do you do when running 93 octance, then bring it to the track and want to run race gas? Thanks for your input
haha....Mike made a funny
but it really pretty much is that simple.......once you add the new fuel, just run it long enough to get all the old stuff out of the lines and your ready to rock and roll
you obviously have to have a tune that allows you to do that though, but at idle, its not really a big deal
try to show up at the track with as little fuel, and then i suppose you could use the fuel return line to drain whatever's left. i've never done it personally, i only use race for a nitrous setup, so it's just an idea.
edit: i just saw you're rockin a VW, i have no idea if your even has a return style fuel system.......ignore my ignorance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin »</TD></TR><TR><TD CLASS="quote">try to show up at the track with as little fuel, and then i suppose you could use the fuel return line to drain whatever's left. i've never done it personally, i only use race for a nitrous setup, so it's just an idea.
i run a return line. i think the easiest way to do it, would be to go there with little gas in tank and almost run it dry at idle. then put the race gas in.
</TD></TR></TABLE>i run a return line. i think the easiest way to do it, would be to go there with little gas in tank and almost run it dry at idle. then put the race gas in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSpin »</TD></TR><TR><TD CLASS="quote">thats pretty much what i was saying, but if you if pull the return line out while the car is running, it will speed the up the process
just be carefull no to get on exhaust, or just run car in accessory mode without the engine on.
</TD></TR></TABLE>just be carefull no to get on exhaust, or just run car in accessory mode without the engine on.
Chris, I do the same thing most of these guys are telling you to. I pull the return line off the rail and put on a separate hose to a gas can. Be sure that you keep the line touching the can while you run the car. Sparks are bad. Refill with desired fuel and run the numbers.
