Squeaking Sound when i turn the Wheels
Old Jan 9, 2005 | 01:11 PM
Convoy's Avatar
Default Squeaking Sound when i turn the Wheels
It does it only when I turn the steering wheel, and it sounds even worse when i make a whole turn. It started around 4 days ago. I jacked the car up and took the wheels off and decided to take a look under the car to see where the sound is coming from, while a friend turned the wheel. I have come to the conclusion that the sound is coming from the passenger side boot, from the steering rack (see pic). My qustion is, Can i replace just the boot? Why would it squeak? What else could it be?? Thanks in advance Its a 91 Integra
Old Jan 9, 2005 | 01:34 PM
virusiidx's Avatar
maybe the powersteering belt, etc...?
Old Jan 9, 2005 | 02:12 PM
the g2 teg's Avatar
Default Re: Squeaking Sound when i turn the Wheels (Convoy)
check your power steering fluid
Old Jan 9, 2005 | 02:14 PM
Convoy's Avatar
i dont have power steering
Old Jan 9, 2005 | 04:23 PM
mugenracer's Avatar
is it coming from the engine bay or from one side of the car..i had a squeaking noise when turning full lock when parking etc, it turned out that the balljoint on the upper control arm was done and needed replacing
Old Jan 9, 2005 | 05:03 PM
Convoy's Avatar
^^I hope its only that, also i just changed the the lower ball joints and upper control arms with ball joints
Old Jan 9, 2005 | 05:46 PM
DOHCGsr's Avatar
Default Re: (Convoy)
mine 94 used to do that 2. only on turns it would make a lound screeching noise. I pulled the tire off and noticed that the brake disc was rubbing on the dust shield. I bent it out and never had a problem since then. hope the new boot will work for ya.
PreludeMatt
Nov 2, 2014 09:06 PM
Black Ack
Dec 6, 2006 03:36 PM
PhatHardy
17
Jan 21, 2003 01:37 PM
