IACV not working ?
Old Jan 9, 2005 | 11:15 AM
SpoolinEK9's Avatar
From: Seattle/Ligonier, WA/PA, United States of Honda
Default IACV not working ?
I have an obd1 ls engine in a 99 civic hatch obd2b with the stock harness and running an obd2b-obd1 harness cant get iacv hooked up properly, orignal iacv on the dx motor was a 3 wire, on the ls motor it is a 2 wire need help!
Old Jan 9, 2005 | 11:19 AM
96MidoriHatch's Avatar
Default Re: IACV not working ? (SpoolinEK9)
you have to get the plug from a b-series harness for the iacv, and cut the plug of off your stock harness. The colors will match up except that there will one left over wire, its orange.
Edit: You also have to repin the b plug http://www.ff-squad.com/tech/w...g.jpg
Old Jan 9, 2005 | 11:33 AM
SpoolinEK9's Avatar
humm must have a bad valve cause i tried that **** both wires everything car has no idle problem unless on the gas between like 18-2500
Dead CIVIC
Jan 28, 2008 03:40 PM
VTcivicHB
Nov 8, 2005 03:44 PM
underage
11
May 25, 2005 12:41 PM
JerKeK9
Jan 19, 2005 09:16 PM
