Im new but I need some help!
Old Jan 9, 2005 | 10:07 AM
tlP-Pres's Avatar
Default Im new but I need some help!
My name is Alex and I am the president an up and coming team. Our name is Team Lo Pro (TLP) check us out at http://www.teamlopro.com. Well my main reason for visiting is I am in the process of getting an LS/vtec for my 2000 honda civic ex and I am in need of a tranny, shift linkage, ecu etc, I think.......
well the specs of the engine is
-B18B 1994 LS Block
-Block Cylinders has been rehoned 81mm
-1995 B18b LS Crank
-B18B Crank has been Micropolished
-Crank has enlarged oil journals for better flow
-Crank has been balanced
-P4 Rods Shotpeened for extra strength
-Brand New Civic Type R Pistons
-Rods have been machined and Wrist pins pressed into Pistons
-New Piston Rings
-New Main Bearings
-New Rod Bearings
-New Head Gaskets
-ARP Head Studs
-B16 Second Generation Head
-High Lift Skunk 2 Stage 2 Spec Camshafts for Major Top end Horsepower
-Head is Freshly Ported and Hot Tanked
-Intake and Exhaust ports ported
-Intake and Exhaust ported polished
-Head Resurfaced and Milled
-Combustion Chamber Polished and Deburred
-Bowl Blended
-3 Angle Valve Job
-Dual Inner Valve springs
-Type R Outer Valve springs
but what tranny is needed, what year tranny and do I need anything else besides what I have listed....do I need custom shift linkage b/c that is what I was told.
please let me know what is needed for the swap to be successful, thanks
Old Jan 9, 2005 | 10:11 AM
Kyles ej1's Avatar
Default Re: Im new but I need some help! (tlP-Pres)
any b series tranny and shift linkage will work, but id get an tranny off an em1 or itr. also try a search,theres tons of info on ls/vtec
Old Jan 9, 2005 | 10:13 AM
skip.two's Avatar
all B-series trannies are interchangeable.
get an ITR or B16 tranny.
not sure, but i think you're going to use the 99-00 Si shift linkage.
maybe somebody will chime in on that.
Old Jan 9, 2005 | 10:14 AM
tlP-Pres's Avatar
Default Re: Im new but I need some help! (93blkej1)
but which one and what year...I have been looking for an ls tranny because it has a long gears (in case I want to do a turbo) but I am having huge prolems finding an ls tranny what years do i need 94-01 or what do I need exactly, thanks for responding as soon as you did!
Old Jan 9, 2005 | 10:18 AM
skip.two's Avatar
yes, get any 94-01 LS tranny, and a 99-00 Si shift linkage.
if you knew which tranny you wanted, why did you ask?
Old Jan 9, 2005 | 10:19 AM
Kyles ej1's Avatar
Default Re: Im new but I need some help! (jL iLLuZiOnz 9)
longer gears w/ turbo is a myth, get a gsr tranny if u go turbo
Old Jan 9, 2005 | 10:26 AM
tlP-Pres's Avatar
I wasn't for sure it was just what I was told in conversation, but since I am having a hard time with finding a hard time with finding one I was wonding what else would work and also beside tranny, shift linkage, possible ecu what else is needed.
Old Jan 9, 2005 | 10:28 AM
tlP-Pres's Avatar
Also does the set-up of the engine sound nice?
Old Jan 9, 2005 | 10:30 AM
Kyles ej1's Avatar
ya how much did u spend?
Old Jan 9, 2005 | 10:31 AM
tlP-Pres's Avatar
$1400 with authentic cerificate of mileage and shipped
Old Jan 9, 2005 | 10:32 AM
skip.two's Avatar
set up sounds good.
use a P28 (D16Z6) ECU, and get it chipped.
Old Jan 9, 2005 | 10:33 AM
Kyles ej1's Avatar
damn 1400, thats pretty good.
Old Jan 16, 2005 | 05:53 AM
tlP-Pres's Avatar
yeah I got if someone who builds engines (Hasport), so is there anything else that I may need!
Old Jan 16, 2005 | 07:32 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tlP-Pres &raquo;</TD></TR><TR><TD CLASS="quote">yeah I got if someone who builds engines (Hasport), so is there anything else that I may need!</TD></TR></TABLE>
Suprised that Hasport didn't tell you what else you needed... But sounds like a nice set up.
Old Jan 17, 2005 | 06:41 AM
tlP-Pres's Avatar
Default Re: Im new but I need some help! (DelSolSiR)
they told me that I need an ecu, shiftlinkage that they will provide and a tranny my engine mounts will work but I was just hoping that someone who has the ls vtec swap could respond to help with any questions that I had to make the process smother
projektvtec
Northeast (Sales)
42
Jul 27, 2006 05:39 PM
projektvtec
May 25, 2006 08:51 AM
projektvtec
Sep 17, 2005 07:52 PM
projektvtec
Sep 8, 2005 05:38 PM
PiMp0r
30
Mar 16, 2005 08:32 PM
