6th Gen Suspicious Noise
Old Jan 9, 2005 | 09:02 AM
tylerzero's Avatar
Default 6th Gen Suspicious Noise
Car is a 1999 Accord V6, no mods.
I just started hearing a humming/whinning sound from the engine that is most noticable when driving under 35 mph. In addition, the pitch changes when I accelerate/decelerate. The car otherwise runs normally.
I know that the transmissions for the 98-99 Accords tend to fail--might this sound be an indication? No CEL appears.
Thanks in advance.
Old Jan 9, 2005 | 02:16 PM
syclone's Avatar
Default Re: 6th Gen Suspicious Noise (tylerzero)
could be the cv joint going bad..
Old Jan 9, 2005 | 02:18 PM
shadow_ridge's Avatar
Default Re: 6th Gen Suspicious Noise (syclone)
thank you thank you.. u got my problem right on the money!
i have this same problem when i got my car out of the shop about 2 weeks ago, after the tranny was rebuilt
Old Jan 9, 2005 | 02:56 PM
'00Accordster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by syclone &raquo;</TD></TR><TR><TD CLASS="quote">could be the cv joint going bad..</TD></TR></TABLE>
True dat. that sound is the sound of your axle going bad. may have to replace it. check the boot see if theres a tear. if there is, repair it as soon as possible, because dirt and ish will get on the ball bearings and you dont want to shell out the cash to replace that AND the axle.
all this is a possibility, i could be wrong
Old Jan 9, 2005 | 03:14 PM
C_H_A_D's Avatar
Default Re: 6th Gen Suspicious Noise ('00Accordster)
I think it might be a bearing in your alternator going bad. I think that's whats going o my 99 did that. Have somebody listen and slowly rev your engine, if it sounds like its coming from the belt I bet that's whats it is. Good luck
Old Jan 9, 2005 | 03:24 PM
Chiovnidca's Avatar
Default Re: 6th Gen Suspicious Noise (VTECJedi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECJedi &raquo;</TD></TR><TR><TD CLASS="quote">I think it might be a bearing in your alternator going bad. </TD></TR></TABLE>
That's my guess too.
RicharDC4
Dec 13, 2005 04:52 PM
ultimateguy
Nov 11, 2005 09:56 PM
ptran
Suspension & Brakes
11
Jul 4, 2005 12:02 AM
tuan...
Aug 2, 2004 06:31 AM
GSR-T-
Jan 21, 2004 09:01 AM
