manifold swap ?'s
i think y8 gasket
and btw...there is a little trick of putting on the center/lower nut on the mailfold (without going under the car and taking off the oil filter and stuff)....the y8 IM should have a hole in center were the pcv hose come out....there u can see that center nut....just use a wrench....and sneak in there....i just swaped out my IM
You need the Y8 gasket. Make sure you clean the old one off really well, I would recommend picking up some liquid gasket remover. What year is your IM from? If its a 99-00 beware of the air injection holes. You will need to seal those up.
AllmotorGSReg
20
Apr 12, 2013 05:57 PM
ej8bori89
May 18, 2011 08:45 PM
mr. carpenter
Apr 20, 2005 01:58 PM
foesicks
Dec 5, 2002 10:35 AM
