Suspension & Brakes Theory, alignment, spring rates....
Koni Yellow SP3 stock perch location?
Old Jan 8, 2005 | 11:23 PM
Greenery18's Avatar
Default Koni Yellow SP3 stock perch location?
Hi, I recently acquired some Koni Yellows, the Neuspeed SP3 versions with 5 rear perch choices. Which of the 5 is considered the same as stock height?
tia.
Old Jan 9, 2005 | 05:14 AM
.RJ's Avatar
.RJ
Default Re: Koni Yellow SP3 stock perch location? (Greenery18)
Just compare with the stock shock
Old Jan 9, 2005 | 06:27 AM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">Hi, I recently acquired some Koni Yellows, the Neuspeed SP3 versions with 5 rear perch choices. Which of the 5 is considered the same as stock height?
tia.</TD></TR></TABLE>
The middle one of the five is stock and there are two each grooves to raise or lower the car a bit more. The grooves are in 8mm increments so the effect of each groove is in the ballpark of an additional half inch but three are other factors that can make that not exact.
Old Jan 9, 2005 | 11:16 AM
Greenery18's Avatar
Default Re: Koni Yellow SP3 stock perch location? (CRX Lee)
Thx for the input guys. I am definately going to compare the 2, although the konis are supposed to have a 20mm shorter stock body, meaning my #'s might be off..
Old Jan 9, 2005 | 11:52 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Greenery18 &raquo;</TD></TR><TR><TD CLASS="quote">although the konis are supposed to have a 20mm shorter stock body, meaning my #'s might be off..</TD></TR></TABLE>
The shock rod is 20mm shorter, not the body!
Old Jan 9, 2005 | 02:38 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Koni Yellow SP3 stock perch location? (.RJ)
It's actually a droop limiter. The shaft is the same length as Yellows (so is the body), but the limiter prevents the shaft from extending all the way (by 20mm). This is to help pass inspection in places were your springs MUST be preloaded at all times to get your vehicle registered.
Old Jan 9, 2005 | 08:09 PM
sleepingEg8's Avatar
I second CRX Lee's response the middle setting is the stock setting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Lee &raquo;</TD></TR><TR><TD CLASS="quote">The middle one of the five is stock and there are two each grooves to raise or lower the car a bit more. The grooves are in 8mm increments so the effect of each groove is in the ballpark of an additional half inch but three are other factors that can make that not exact.</TD></TR></TABLE>
freakaccident
10
Jan 20, 2007 06:02 PM
98GSRDC2
Suspension & Brakes
Jul 23, 2006 02:01 PM
rikawa
Suspension & Brakes
Dec 17, 2005 07:30 AM
stock99
Suspension & Brakes
Nov 1, 2005 07:04 PM
PatrickGSR94
Mar 31, 2003 08:04 AM
