need help asap!!!!!!!
please help my car wont start it just keeps turning over has fuel and spark i checked it but motor doesnt start its a d15b2 with a si head i really need help so please help me thanx for those who help in advanced
did you switch to mpfi if so check your wiring if not check to see if it gets spark you can do that by putting a spark plug in the wire and holding by an engine ground and cranking it and make sure your firing order is right on
yes it has spark and its still dual point, my friend told me i need a si distributor to run it all i need is for it to run ill be picking up a multi point mani later but thanx to whom ever helps
You dont need a si dizzy for a dpfi set up..The dx dizzy should work fine for now untill you get the mpfi swap..
You say it has fuel and spark,, so maybe the timing is off..
