Help with Alpine iva d900
I bought a used alpine dvd player on ebay and it seem to be missing the power supply harness and the dc/dc converter that goes behind the screeen. I tried it with just the battery and ground wires to see if it turns on, but no luck.
I was just wondering if I need to the dc/dc converter to get it on. And do I need to install everything including all the wires from the brain? I just need to have the screen to have power to see if it works or not.
I know other head just need power and groud wires connected to get it on. So help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaznxboixsirx »</TD></TR><TR><TD CLASS="quote">I bought a used alpine dvd player on ebay and it seem to be missing the power supply harness and the dc/dc converter that goes behind the screeen. I tried it with just the battery and ground wires to see if it turns on, but no luck.
I know other head just need power and groud wires connected to get it on. So help.</TD></TR></TABLE>If you are missing parts, your not going to be able to get it to turn on, if by "brain" you mean the offboard switcher, yes it has to be wired, you dont' need to wire up the foot and E brake to see if it turns on, you will see the safety warning.
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm »</TD></TR><TR><TD CLASS="quote">If you are missing parts, your not going to be able to get it to turn on, if by "brain" you mean the offboard switcher, yes it has to be wired, you dont' need to wire up the foot and E brake to see if it turns on, you will see the safety warning.
94</TD></TR></TABLE>
What's an offboard switcher? I was talking about the tuner box. (brain)
anyways, all i'm missing is the connector which I can solder wires back into. But what is the dc/dc converter they show here on the manual that splits out from the connector behind the monitor?
94</TD></TR></TABLE>What's an offboard switcher? I was talking about the tuner box. (brain)
anyways, all i'm missing is the connector which I can solder wires back into. But what is the dc/dc converter they show here on the manual that splits out from the connector behind the monitor?</TD></TR></TABLE>The dc/dc converter is one of the parts you will need to get the unit to work
the switcher is just that, the tuner the amp and all switching is done in that offboard unit, ["brain"]
94
94
I've played with pioneers and panasonic dvd players, but this is the first time getting my hands on alpine. they have more stuff than others.
anyone knows wheere i can get a dc dc converter?
. anyone knows wheere i can get a dc dc converter?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xaznxboixsirx »</TD></TR><TR><TD CLASS="quote">I've played with pioneers and panasonic dvd players, but this is the first time getting my hands on alpine. they have more stuff than others.
anyone knows wheere i can get a dc dc converter?</TD></TR></TABLE>Try your local Alpine repair shop, or check at http://www.alpine.com for a parts supplier
94
. anyone knows wheere i can get a dc dc converter?</TD></TR></TABLE>Try your local Alpine repair shop, or check at http://www.alpine.com for a parts supplier
94
Honduh Chicken
Audio / Security / Video
16
Aug 7, 2007 11:20 AM
