+5 DB or +0 DB for tweeters?
Old Jan 8, 2005 | 03:26 PM
noob with an RS's Avatar
Default +5 DB or +0 DB for tweeters?
i have a set of infinity perfect 6.1 components. should i set the tweeter jumper setting on the crossover to +0 DB or +5 DB ?? what are pros and cons of each?
Old Jan 8, 2005 | 06:14 PM
t0p_sh0tta's Avatar
Default Re: +5 DB or +0 DB for tweeters? (noob with an RS)
Set it to what sounds best to you.
The Infinity has what some people would refer to as an aggressive tweeter. It's very detailed and pronounced IMO. If you like the tweets loud/aggressive set it to +5, then again maybe you like it the way it is. In the end it's what you like. Try each setting.
Old Jan 8, 2005 | 08:09 PM
fcm's Avatar
fcm
Old Fart
Default Re: +5 DB or +0 DB for tweeters? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">Set it to what sounds best to you.
The Infinity has what some people would refer to as an aggressive tweeter. It's very detailed and pronounced IMO. If you like the tweets loud/aggressive set it to +5, then again maybe you like it the way it is. In the end it's what you like. Try each setting. </TD></TR></TABLE> Ditto all the above 94
Old Jan 8, 2005 | 09:38 PM
imma leave them at +5 db.. your answer was what my guess would be.. and i want MINE to scream!!
Mr.E.G.
Welding / Fabrication
13
May 16, 2007 04:27 PM
lanceh
Jul 14, 2004 11:11 AM
