Need help on a ITR manifold in a B16???
Old Jan 8, 2005 | 02:45 PM
92_EGhatch's Avatar
Default Need help on a ITR manifold in a B16???
I installed a itr manifold into my B16 and it sounds leaked. What i used is the stock manifold gasket because it's still good, stock B16 Throttle, ANd most of the stuff from my b16 manifold is on the ITR manifold. What Happen.???
Old Jan 8, 2005 | 03:40 PM
KiLLa CaM 06's Avatar
Default Re: Need help on a ITR manifold in a B16??? (92_EGhatch)
check your vaccum lines
Old Jan 8, 2005 | 04:34 PM
ekek888's Avatar
leak makes a sound. to find out where, make a ghetto stetoscope and probe where the leak is, it should be then easy to fix except if the mani is not flat.
Old Jan 8, 2005 | 06:14 PM
DavidT or VajT's Avatar
Default Re: Need help on a ITR manifold in a B16??? (ekek888)
Spray some carb cleaner around your intake manifold. Where it leaks, it should also bubble. Good luck!
Old Jan 8, 2005 | 06:59 PM
eda6's Avatar
Default Re: Need help on a ITR manifold in a B16??? (DavidT)
Did you torque the bolts to 18 ft.lbs starting in the middle? Use carb cleaner. When the leak is located the idle will change.
dutchman5
Texas -OK -LA (Sales)
Oct 29, 2010 12:50 PM
an2ny888
Sep 27, 2005 01:21 AM
