Honda S2000 Honda S2000
Swapping clutch need a few answers
Old Jan 8, 2005 | 10:34 AM
GradyDC5's Avatar
Default Swapping clutch need a few answers
Need the torque specs on pressure plate bolts, flywheel bolts, and the driveshaft bolts. Is there any other things I should look out for while swapping clutches ?
Thanks, Grady
Old Jan 8, 2005 | 11:05 AM
y2ks2k's Avatar
Default Re: Swapping clutch need a few answers (ReallySlowEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallySlowEg &raquo;</TD></TR><TR><TD CLASS="quote">Need the torque specs on pressure plate bolts, flywheel bolts, and the driveshaft bolts. Is there any other things I should look out for while swapping clutches ?
Thanks, Grady</TD></TR></TABLE>
pressure plate is 25NM/19lbf*ft
flywheel is 127NM/94lbf*ft
and i think ur talking about the propeller shaft that goes to the rear and its 32NM/24lbf*ft
Old Jan 8, 2005 | 11:09 AM
GradyDC5's Avatar
Thank you very much. Also is there an easy way to remove the trim around the center console to get the shifter out ?
Old Jan 8, 2005 | 11:52 AM
papa5murf's Avatar
Default Re: (ReallySlowEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReallySlowEg &raquo;</TD></TR><TR><TD CLASS="quote">Thank you very much. Also is there an easy way to remove the trim around the center console to get the shifter out ? </TD></TR></TABLE>
there's only one way.. you pop it out.. it's just put in with snaps.... so stick your fingers in one side and lift up and it'll pop up..
Old Jan 8, 2005 | 08:35 PM
Nishant's Avatar
Default Re: (03s2kblue)
buy a helm's or oem service manual. its worth it, shows exact steps
Old Jan 8, 2005 | 08:40 PM
BOOSTEDS2K's Avatar
what clutch are you putting in?
Old Jan 8, 2005 | 09:30 PM
papa5murf's Avatar
Default Re: (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">buy a helm's or oem service manual. its worth it, shows exact steps </TD></TR></TABLE>
i need a helms manual.. but i can't find it anywhere...
Old Jan 8, 2005 | 10:39 PM
hadboosttroy's Avatar
http://www.helminc.com/helm/Re...CAL8C
70 bux
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">
i need a helms manual.. but i can't find it anywhere... </TD></TR></TABLE>
Old Jan 8, 2005 | 10:42 PM
papa5murf's Avatar
Default Re: (hadboosttroy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hadboosttroy &raquo;</TD></TR><TR><TD CLASS="quote">http://www.helminc.com/helm/Re...CAL8C
70 bux
thanks..
Old Jan 9, 2005 | 07:25 PM
Nishant's Avatar
http://www.hardtopguy.com call and talk to jeff, he'll send you one. i got mine from him
Old Jan 9, 2005 | 09:54 PM
GradyDC5's Avatar
I went with an oem clutch kit because I hate my car. Time to sell this peice of dog doo. So, one obsticale after another to even get the tranny out. Now my problem is I have the tranny completely unbolted it comes foward 2 almost 3 inches, and I can't get it to come out.
Almost ready to take it to Honda, and let them put it back together. Honda went out of their way to make this car hard to work on.
Old Jan 10, 2005 | 08:36 AM
GradyDC5's Avatar
bump
snzh22
Jun 13, 2008 01:06 AM
JDM turbo DC
Aug 28, 2007 07:42 PM
TurboTeG4
Oct 21, 2004 11:58 AM
Grnade
Jun 1, 2004 01:18 PM
crxgurlllll
11
Dec 10, 2002 09:23 AM
