B16 water pump hell
Old Jan 8, 2005 | 10:03 AM
CsRiX's Avatar
Default B16 water pump hell
hey all, I am in the process of droping my B16a1 engine into my 88 CRX si. I have gotten all the parts i need to replace and the timing belt and water pump from a 94+ Del Sol DOHC vtec.
Now the problem is that the water pump has 19 teeth and my old one has 22. I have been looking and from everyone i have talked to said it should have 22.
The guy at the Honda dealership didnt have any 00 civic si pumps for me to count but said that the one with 19 should be ok on it. He said it will of course spin faster and could actually promote more efficient cooling.
So is this guy blowing smoke up my *** or is he right and if so could it harm my engine if i do use it.
TIA
Old Jan 8, 2005 | 10:10 AM
johnzm's Avatar
Default Re: B16 water pump hell (CsRiX)
the teeth arent important IMO but u got it from HONDA and not from ACURA that means u are set, just make sure u get the timing belt from the same car
LS uses a different tooth water pump, and timing belt as well, but as long as the belt+ water pump match up u are fine
Old Jan 8, 2005 | 10:11 AM
CsRiX's Avatar
Default Re: B16 water pump hell (johnzm)
Yes both are form a Del Sol. thanks a lot
Old Jan 8, 2005 | 11:18 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
also see below:
Modified by 88DXCRX at 3:26 PM 1/8/2005
Old Jan 8, 2005 | 11:23 AM
skellator_thoj's Avatar
Default Re: B16 water pump hell (88DXCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX &raquo;</TD></TR><TR><TD CLASS="quote">This info was given to me by member "Monty"
and was accurate for everything I replaced:
Water Pump 19200-P30-003 94 - del sol
Head Gasket 12251-P30-014 94 - del sol
Oil Control Orifice O ring 15142-PH3-003 94 - del sol
Intake Manifold Gasket 17105-P30-004 94 - del sol
Exhaust Manifold Gasket 18115-P30-013 94 - del sol
throttle Body Gasket 16176-PR3-010 90-91 integra
Pcv valve 17130-PM6-G01 94 - del sol
Timing Belt 14400-PR3-004 94 - del sol
Alternator Belt 31110-PR3-003 94 - del sol
Tensioner 14510-P30-003 94 - del sol
Thermostat 19301-P08-305 90-91 integra / 94 del sol (same)
Connecting Pipe O rings (2) 91314-PH7-003 90-91 integra / 94 del sol (same)
Cap & Rotor Assembly 06303-PR4-000 90-91 integra
Rotor (If needed seperately) 30103-PR3-016 90-91 integra
Clutch Cable 22910-SK7-A02 90-91 integra
Throttle Cable 17910-SK7-A03 90-91 integra
Cam Seals (2) 91213-PR3-004 94 - del sol
Oil pan seal 11251-P30-004 94 - del sol
Oil Pump (comes with crank seal) 15100-PR3-024 94 - del sol
Oil Filter 15400-POH-305 94 - del sol
Oil Pick Up Gasket 15221-PW0-S01 94 - del sol
Shift linkage bushing 54303-SB2-010 90-91 integra
crank seal 91212-PR3-003 94 - del sol
rear main seal 91214-PH1-004 90-91 integra / 94 del sol (same)
Valve cover grommets (8) 90442-P30-000 94 - del sol
Spark Plug O rings (4) 12342-P66-000 94 - del sol
Rubber plug for exhaust cam tranny side 94 - del sol
Spark Plugs (4) BKR6E-N11 NGK
Spark Plug Wires 32722-PR4-A01 92 - integra gsr
Upper Radiator Hose 19501-PR3-000 92 - integra gsr
Lower Radiator Hose 19502-PR4-A00 90-91 integra
Bypass Hose (Thermostat) 19508-P08-000 94 - del sol
Washer for coolant drain on block 90401-PR4-000 94 - del sol
GOOD INFO!!
Old Jan 8, 2005 | 12:28 PM
88DXCRX's Avatar
Default Re: B16 water pump hell (skellator_thoj)
Not sure of accuracy:
Other info found:----??????
Axles (S1 intermediate shaft) Integra '90-'91, any make (non-ABS).
Throttle Cable '90-'91 Integra, any model. Part # 17910-SK7-A03 (Acura)
Clutch Cable '88-'91 CRX Si, may require modification to fit.
Shift Linkage + Torque Rod '90-'93 Integra, requires modification to fit, or buy pre-cut (highly advised)
Clutch Disc Integra non-GSR, '90-'91.
Clutch Plate Integra non-GSR, '90-'91 (?????)
Throwout/release bearing Integra GSR, '92-'93 (?????)
Flywheel bearing Integra GSR, '92-'93 (?????)
Cam seal endplug Part # 12513-P30-000
Oil Filter Integra GSR, '92-'93.
Valvecover Gasket Part # 12341-PR3-000. del Sol VTEC '94+.
Oil Pan Gasket Part # 11251-P30-004, del Sol VTEC '94+.
Intake Manifold Gasket Part # 17105-P30-004, del Sol VTEC '94+.
Exhaust Manifold Gasket Part # 18115-P30-013, Del Sol VTEC, '94+.
Rear coolant hose (IACV?) Part # 19507-PR3-000 (Honda)
Cam Seals Part # 91213-PR3-013 (Honda)
Cam seal endplug Part # 12513-P30-000 (Honda)
Spark plug tower seals Part # 12342-PG6-000 (Honda)
Valve cover grommets Part # 90442-P30-000 (Honda)
Timing belt cover gasket Part # 11831-PR3-000 (Honda)
Head gasket del Sol VTEC '94+
Fuel injector O-rings Part # 91301-PM7-003, del Sol VTEC '94+
Fuel injector rail cushions Part # 16473-PD6-000, del Sol VTEC '94+
Distributor Cap and Rotor Integra non-VTEC kit from Acura ('90-'91 Integra LS) Part # 06303-PR4-000
Water Pump Part # 19200-P30-003, from a '92-'93 Integra GSR.
Front + Rear Crank Seal Integra GSR, '92-'93.
Throttle body gasket Integra LS, '90-'91 (????). del Sol VTEC does NOT fit.
IACV seal CRX Si, part # 36455-PR4-A01
IACV CRX Si
Upper + Lower Radiator Hose del Sol VTEC, '94+.
Timing Belt Part # 14400-PR3-004, del Sol VTEC '94+.
Spark Plugs Part # BKR6E-11 (NGK copper) GAP: 0.039-0.043
Rear Transmission Bracket Part # 50827-SK7-020, '90-'93 Integra non-VTEC (80% sure)
Coolant hose, back of block to intake manifold Part # 19507-PR3-000, del Sol VTEC '94+.
Modified by 88DXCRX at 9:13 PM 1/8/2005
the soL that could
Honda Civic (2001 - 2005)
Jan 12, 2011 09:40 PM
cincyb20ek
May 5, 2010 04:51 PM
EG2Driver
Jan 8, 2006 06:31 PM
aaronhume
13
Feb 21, 2005 07:24 PM
bluecrxsi
Feb 5, 2003 07:20 PM
