brake swap q's: please help
Old Jan 8, 2005 | 04:22 AM
alexb16hb's Avatar
Default wilwood brake: compatibility through civic generations
Can I get the Willwood (front) brake kit off a 88-91 civic to fit on my 95 civic cx. If so do these brakes fit in a 16 in wheel. Your help is greatly appreciated. Thanks
Modified by alexb16hb at 3:02 PM 1/9/2005
Old Jan 8, 2005 | 12:59 PM
alexb16hb's Avatar
Default Re: brake swap q's: please help (alexb16hb)
any body have any ideas
Old Jan 9, 2005 | 11:56 AM
alexb16hb's Avatar
any one
Old Jan 9, 2005 | 12:54 PM
mrlover's Avatar
Default Re: wilwood brake: compatibility through civic generations (alexb16hb)
yes, they will fit on 16" wheels. not stock 16", have to be after market wheels
Old Jan 9, 2005 | 01:29 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexb16hb &raquo;</TD></TR><TR><TD CLASS="quote">Can I get the Willwood (front) brake kit off a 88-91 civic to fit on my 95 civic cx. If so do these brakes fit in a 16 in wheel. Your help is greatly appreciated. Thanks
Modified by alexb16hb at 3:02 PM 1/9/2005</TD></TR></TABLE>
I know for sure the knuckles from an EF will NOT fir on an EG. Not even close. The calipers, rotors, pads, and brake lines should work with no problem, if that is what you are asking.
Old Jan 9, 2005 | 01:38 PM
alexb16hb's Avatar
Default Re: wilwood brake: compatibility through civic generations (Hybrid93Eg)
ok....so is it possible to make them work if I get others parts and if so what would I need! Thanks
Old Jan 11, 2005 | 10:40 AM
alexb16hb's Avatar
any one have any more info for me!
triple lobe
May 27, 2008 09:54 PM
CARMA_626
May 16, 2005 01:14 PM
alexb16hb
Jan 14, 2005 04:46 PM
alexb16hb
Jan 7, 2005 04:17 PM
