axel removal problem.... i have pics
Old Jan 7, 2005 | 05:46 PM
maxheat's Avatar
Default axel removal problem.... i have pics
Well, i finally got the new tranny ready to bolt in but now i run into another problem... the axels wont come outta the tranny. i used a small crowbar to try and pry out the axel but it comes out a little bit then stops.... i gave up today cause it started to **** me off after messing with it for hours so now i need help. and yes i took off the axel hub nut from the brake disk. Here are the pics
Old Jan 7, 2005 | 05:56 PM
99hatch's Avatar
Default Re: axel removal problem.... i have pics (maxheat)
axle puller maybe? you can prolly rent one if you dont have one
Old Jan 7, 2005 | 06:08 PM
maxheat's Avatar
how much does that cost..
CivicHatchback14's Avatar
have one person put a pry-bar on that sucker and have another Jiggle it like a Mo Fo. It should come out has always worked for me. Some are just pretty stubborn. You'll get it.... just a little time.
Old Jan 7, 2005 | 06:13 PM
99hatch's Avatar
Default Re: (maxheat)
its prolly like 15 a day or somethin like that
Old Jan 7, 2005 | 06:14 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: axel removal problem.... i have pics (CivicHatchback14)
use a slide hammer
Old Jan 7, 2005 | 06:18 PM
DONFRH's Avatar
A i would remove tranny with axle still attached.Install new tranny then work on removal of axle with large pry-crow bar to remove axle.The axle has clip ring that might be stuck in DIFF. ?did u remove from axle from inside brake rotor .....
Old Jan 7, 2005 | 06:44 PM
maxheat's Avatar
Default Re: axel removal problem.... i have pics (DONFRH)
thats what i tried to do... i tried pushing them out and dropping them down then sliding them out from the opposite end but it still didnt budge. and i tried using a damn rubber hammer banging against the crowbar and still didnt come out so now what?
Old Jan 7, 2005 | 06:49 PM
senpai's Avatar
sometimes it's just a **** like that; keep working at it, don't spend money
Old Jan 7, 2005 | 06:52 PM
Luserkid's Avatar
Default Re: axel removal problem.... i have pics (senpai)
Do you have plenty of room to move it out? Like is your hub free so you could pull it out?
Just keep at it, just becareful because if you dont pay attention you could bring it lose and itll hit you in the head. Just keep working at it and jiggle too. Also a bigger prybar might help too.
Old Jan 7, 2005 | 06:54 PM
SOHC4life 96's Avatar
Default Re: axel removal problem.... i have pics (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Just keep at it, just becareful because if you dont pay attention you could bring it lose and itll hit you in the head.</TD></TR></TABLE>
You would know huh?
Yeah, you'll learn that there is a lot of jiggling and shoving and what not when working on any part of the tranny.
Old Jan 7, 2005 | 07:15 PM
maxheat's Avatar
alright ill try that.... good thing it didnt come out cause i was laying right under it lol
Old Jan 7, 2005 | 07:18 PM
maxheat's Avatar
i actually tried to jack up the disk brake making the axel straight but that still didnt work. but tomorrow morning ill try and jiggle it and *** with it somemore and tell yall the results thanks for the help
hayabusa160's Avatar
i used a big metal spike lay it on the end grab my 4 pound sledge hammer and 2 good wacks she comes right out. works for me everytime.
other time i used a 2x4 and a hammer.
Old Jan 7, 2005 | 07:19 PM
jbell's Avatar
use a gigantic prybar.
worked for my friend's car when his was STUCK
Old Jan 7, 2005 | 07:30 PM
del_orson's Avatar
did you undo the lower ball joint and moved the spindle out of the way. If not, you will not get the axle out.
Old Jan 7, 2005 | 07:32 PM
del_orson's Avatar
Did you undo the lower ball joint and move the spindle out of the way?
Old Jan 7, 2005 | 07:33 PM
del_orson's Avatar
Default Re: (jbell)
Old Jan 7, 2005 | 07:38 PM
maxheat's Avatar
Default Re: (del_orson)
yes i removed the ball joint but i dont think i moved the spindle outta the way ill take more pics tomorrow of EVERYTHING if i still have problems
Old Jan 7, 2005 | 07:42 PM
Street Ghost's Avatar
You said you took off the axle nut but did you take the axle out of the hub yet?
Old Jan 7, 2005 | 07:46 PM
maxheat's Avatar
dont think i did so how would i go about doing that?
Old Jan 7, 2005 | 07:47 PM
maxheat's Avatar
sorry im a real nub when it comes to working on cars. hardest **** i did was wire up my tach with no instructions lol
if someone could give me a tutorial on how to remove the axels that would be more than GREAT!!! and trust me i searched for anything
Old Jan 7, 2005 | 08:35 PM
tony's Avatar
Axle replacement
https://honda-tech.com/zerothread?id=382416
FAQ up top
I worked on A mazda protege once and it took me and a friend at least 8 hours.
it was a pain. It just takes time Don't give up.
Old Jan 7, 2005 | 08:36 PM
DONFRH's Avatar
A put the axle back in the tranny and with a hammer tap on the other side of the axle were u removed the axle bolt .alright get that end out first because if u had to jack the brake rotor to straighten out the axle .that means the axle.. is still in the hub-rotor-disc brake .......
Old Jan 7, 2005 | 09:17 PM
BauleyCivic's Avatar
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_orson &raquo;</TD></TR><TR><TD CLASS="quote">Did you undo the lower ball joint and move the spindle out of the way?</TD></TR></TABLE>
