stripped main studs
i think i stripped my civics main studs, i used my headstuds and started to turn, tight, and before you knew it it turned again and again... i was using a breaker bar and i'm so strizz song.
Think its cause it was from using headstuds in the main stud ones.... how expensive/hard can this be to fix. Also does anyone know where i can get a gasket kit for a d16y7 pretty cheap.
Modified by menkio at 11:19 PM 1/7/2005
I apologize ahead of time right now if my answer isn't what you're looking for or wrong, as I am a little intoxicated right now.....(friday early "morning")
You wouldn't happen to be talking about them things that hold the valve cover on, would you? If you are, I vaguely remember how much, but I'm thinking that it was around only 20 bucks CND for the part from Honda.
But I was also wondering why you would use a breaker bar on your valve cover nuts?
Hope that helps
Hope that helps
