head gasket or water pump?
theres antifreeze coming leakin to the floor. and it seems to be coming from the timing belt area. would this be a bad head gasket or a bad water pump. im thinkin its the head gasket but few people told me otherwise.
any help?
any help?
Check your oil for coolant, check to see if white smoke is coming from exhaust. If not most likely if coming from timing belt area its a bad waterpump seal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">I would guess a water pump.</TD></TR></TABLE>
I concur.
I concur.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirRevvs »</TD></TR><TR><TD CLASS="quote">Check your oil for coolant, check to see if white smoke is coming from exhaust. If not most likely if coming from timing belt area its a bad waterpump seal.</TD></TR></TABLE>
coolant doesnt always end up in the oil.
and it sounds like the waterpump has gone bad, or the seal has.
i couldnt see any anti freeze in the oil.
but it looked like theres some oil in the radiator.
so its either the water pump or water pump gasket.
thanks you guys the ****** best!
What if you got the little leak from timing area, white smoke, and no oil in coolant, and no coolant in oil?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsmike »</TD></TR><TR><TD CLASS="quote">
What if you got the little leak from timing area, white smoke, and no oil in coolant, and no coolant in oil?</TD></TR></TABLE>
Then check your hoses.
From: chillin in that city called queen creek, but homes the atl
if water is dripping from the timing belt side its your water pump,your water pump,your water pump,your water pump end of question
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street dreams »</TD></TR><TR><TD CLASS="quote">if water is dripping from the timing belt side its your water pump,your water pump,your water pump,your water pump end of question</TD></TR></TABLE>
Would this cause white smoke to come out of the tailpipe? (a lot of smoke)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonef »</TD></TR><TR><TD CLASS="quote">From what i can remmeber yes also smell a little of the exhaust air and describe it to us</TD></TR></TABLE>
yeah stick your mouth on the exhaust pipe and tell us how it tastes and we will surely have an answer for u
naw really if your exhaust smells like coolant than your head gasket is fucked. pull your plugs see if they have coolant on them and is your car styarting to overheat
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRcivicGSR »</TD></TR><TR><TD CLASS="quote">i couldnt see any anti freeze in the oil.
thanks you guys the ****** best!</TD></TR></TABLE>
If you just recently took the head off the block then there is a chance some oil got into the coolant gallies like what happened to my car. If not then I would think it was a bad headgasket because oil doesn't just end up in your radiator unless you pour it in there or your headgasket is effed.
and to the originator of this post u might as well change the timing belt and the water pump since u are going to need to replace the head gasket
