can i put my b16a2 into a crx?
Old Jan 7, 2005 | 06:45 AM
dobbs1027's Avatar
Default can i put my b16a2 into a crx?
if so what all would i need?i just got the motor and put it in my 93 delsol si,a week ago i rear ended someone and dont feel like fixing it so just wondering if it would go?
Old Jan 7, 2005 | 07:00 AM
WhiteDSM520's Avatar
Default Re: can i put my b16a2 into a crx? (dobbs1027)
theres about a bajillion threads on this give the search function here a go. It's awsome.
But these are the basics of what you'll need
-obd0 dizzy
-axles
-mounts
-linkage
-ecu
-clutch cable
-throttle cable
-cable transmission
Old Jan 7, 2005 | 07:25 AM
slowpokesi's Avatar
Default Re: can i put my b16a2 into a crx? (WhiteDSM520)
or instead of buying a bunch of parts you already have,
you could buy a obd0-> obd1 conversion harness, and get the hasport hydro/cable conversion setup, then you can use everything you have! and wont have to buy extra ****!
Old Jan 7, 2005 | 07:26 AM
Slopoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteDSM520 &raquo;</TD></TR><TR><TD CLASS="quote">theres about a bajillion threads on this give the search function here a go. It's awsome.
-obd0 dizzy
-axles
-mounts
-linkage
-ecu
-clutch cable
-throttle cable
-cable transmission</TD></TR></TABLE>
That is not the cheapest way to do things.
If you have the full swap out of your delsol, you need:
-hasport mount kit(with cable to hydro conversion)
-obd0-obd1 jumper harness
-shift linkage(or cut and weld you b16 linkage)
-throttle cable(or make a new bracket for your current cable)
-Modify your stock engine harness to fit the b16a.
You can use the '94-up b series axles in the crx as long as your also using the '94-up intermediate shaft.
And since you'll be converting to obd1, just reuse the obd1 b16 ecu that is currently in the sol.
Edit* slowpokesi types faster than me.
Modified by Slopoke at 9:11 AM 1/7/2005
Old Jan 7, 2005 | 07:40 AM
slowpokesi's Avatar
Default Re: can i put my b16a2 into a crx? (Slopoke)
its my alter ego
woah
Old Jan 7, 2005 | 08:10 AM
Slopoke's Avatar
Default Re: can i put my b16a2 into a crx? (slowpokesi)
lol
bunkrd you
15
Aug 29, 2011 10:53 AM
92integracer
Jul 26, 2007 02:48 PM
808JdmRex
Jul 24, 2007 03:46 PM
RI_TM
Jul 8, 2004 02:13 PM
ACRXGuy
Nov 21, 2003 07:48 PM
