Hytech Header=+20HP and 22ft/LBS.
Old Jan 8, 2002 | 08:19 PM
ThePunk's Avatar
Default Hytech Header=+20HP and 22ft/LBS.
The new Sport compact car (Feb 2002) has a mention of the Hytech header in their "B series Guide". According to john of Hytech, the header on a STOCK typr-R with only a VAFC made 20 Horsepower and 22 lb-ft of torque. As well as a 10 hp gain at 2500 rpm...
(ThePunk dons his flame-proof suit and ducks for cover)
[Modified by ThePunk, 9:45 PM 1/8/2002]
Old Jan 8, 2002 | 08:21 PM
B2FiNiTY's Avatar
Default Re: Hytech Header=+20HP and 22ft/LBS. (ThePunk)
I see on his site that it says up to 20HP for a fully tuned car. I doubt on a stock car. Probably 10 at most..
Old Jan 8, 2002 | 08:24 PM
Type R's Avatar
Default Re: Hytech Header=+20HP and 22ft/LBS. (B2FiNiTY)
damn thats alot of hp and tq.. i think the car would need a little more mods to see those kind of gains.
Old Jan 8, 2002 | 08:31 PM
AllMotorITR's Avatar
New User
Default Re: Hytech Header=+20HP and 22ft/LBS. (Type R)
I believe it.. John may not have the nicest rep around here, but his products are top notch!
Old Jan 8, 2002 | 08:33 PM
Padawan's Avatar
Darth ModerVader
The key phrase there is "with only a VAFC". As shown in The Great Header Test, a decent header and highflow cat/testpipe will yield very good results on its own. Combined with extensive fuel and vtec x-over tuning via a V-AFC, those numbers would be even better. There is no disputing that Hy-Tech's products are some of the best in the industry, but the dyno results you quoted would have been significantly lower had the header and exhaust simply been bolted on without any further tuning. Also, keep in mind that Hy-Tech's headers are designed to truly shine when used on semi/highly modded motors, and not as simple bolt-on pieces.
Old Jan 8, 2002 | 08:56 PM
ThePunk's Avatar
Default Re: Hytech Header=+20HP and 22ft/LBS. (SpecR0123)
The article (now shown above) does not mention exhaust or a high flow cat/ test pipe... Just header and VAFC.
Old Jan 8, 2002 | 09:17 PM
Mike M's Avatar
Founding Member
John posted this here months ago, It was a stock ITR I believe a 00 model with His header cat and exhaust and a VAFC with some tuning
Old Jan 8, 2002 | 09:46 PM
Padawan's Avatar
Darth ModerVader
One of the old threads: https://honda-tech.com/zerothread?id=53565
[Modified by SpecR0123, 1:48 AM 1/9/2002]
Old Jan 8, 2002 | 10:09 PM
ThePunk's Avatar
That's a real good advertising technique... "This header on a stock type-r with a vafc controller made 20HP and 22lb-ft." Nice to see he fails to mention the highflow cat (or test pipe) and full exhaust system.
I could get a pacesetter header to show +50 hp on a "stock" type-r (if I accidentally failed to mention the 100 shot of naawwzz yo!)
Old Jan 8, 2002 | 10:37 PM
Toda Party's Avatar
lol
Old Jan 9, 2002 | 03:58 AM
sgT's Avatar
sgT
A VAFC alone is NOT extensive fuel tuning.
Old Jan 9, 2002 | 06:18 AM
La Chilindrina's Avatar
Default Re: Hytech Header=+20HP and 22ft/LBS. (sgT)
I hit 165 stock on a dyno jet..After I got my header installed, I dynoed on a clayton and hit 180 with i/h and vafc....Then I dynoed on a dynojet again, and hit 175.
Just thought I would share that.....
Old Jan 9, 2002 | 06:26 AM
Black R's Avatar
25 Year Member
Default Re: Hytech Header=+20HP and 22ft/LBS. (NiNeD8iNtEgTyPeR1109)
Was this a hytech header?
Old Jan 9, 2002 | 07:06 AM
sgT's Avatar
sgT
Default Re: Hytech Header=+20HP and 22ft/LBS. (Black R)
yeah, pretty sure she has a hytech
Old Jan 9, 2002 | 07:08 AM
Austin's Avatar
Marlene has a HyTech header, stock cat, and stock exhaust.
Hey Marlene, do you have any charts? I'll be back in town in a couple of weeks with a friends B20, and another itr.
Austin
Old Jan 9, 2002 | 07:53 AM
Default Re: Hytech Header=+20HP and 22ft/LBS. (Austin)
Yes Austin.....I have 3 charts from a dynojet, and then the one from the clayton....
I was thinking about going to the dyno day at area 51 on the 20th if anyone is interested....
Old Jan 9, 2002 | 07:58 AM
Black R's Avatar
25 Year Member
She's almost as bad as me! I've got the stock catback and a testpipe with my spec b's, but she has the stock cat too?
Damn we need to ditch this stock crap. Marlene, this would be an opportune time to get the hytech cat and twinloop exhaust huh?
Old Jan 9, 2002 | 08:06 AM
I have been trying to for 5 months now
I know John is hella busy with other projects, so all I can do is wait by the phone till he calls me and says "I have time for you now"
Old Jan 9, 2002 | 08:36 AM
Austin's Avatar
My sentiments exactly...
Area 51 damn that's one hell of a drive girl.
Austin
Old Jan 9, 2002 | 09:42 AM
Black R's Avatar
25 Year Member
.....well I'll contact you when I have my "temporary" exhaust solution figured out then. It should be sub ~$100 and use an exhaust cutout/ test pipe/ cat configuration behind the header... "off-road/ race only" setup, but great if you want to scare the **** out of ricers too... I expect to have this in place within the next 30 days...
Old Jan 9, 2002 | 09:48 AM
LOL!!!!! Scaring the ricers is the best!!!!
Old Jan 9, 2002 | 12:38 PM
Padawan's Avatar
Darth ModerVader
What I meant by extensive was that its probably safe to assume that the test car spent a good deal of time on the dyno getting the fuel and VTEC settings to an optimal point. Chances are that it didn't just make 2 or 3 pulls with a few changes to the fuel curve here and there. However, I wasn't at the tuning session so I could be mistaken. It just seems logical that every effort possible to get power out of the setup would be taken before the numbers were posted here or on other sites.
[Modified by SpecR0123, 4:43 PM 1/9/2002]
Old Jan 9, 2002 | 12:48 PM
Michael Delaney's Avatar
who puts on a part without tuning afterwards to get the most out of that part?
Old Jan 9, 2002 | 12:49 PM
Black R's Avatar
25 Year Member
Default Re: Hytech Header=+20HP and 22ft/LBS. (Michael Delaney)
.....sadly most do.
Old Jan 9, 2002 | 12:55 PM
Austin's Avatar
This car belongs to vagoITR, the dyno tuning was done at Area51, which isn't all that far from where HyTech is located, and I don't think that it had all that much dyno tuning. Just adding in the information that I have.
Austin
