95 gsr tranny in crx what vss
Old Jan 6, 2005 | 07:24 PM
HELICALB16's Avatar
Default 95 gsr tranny in crx what vss
i ordered the hasport conversion kit but what vss sensor do i use , the cable vss thats on the crx or the one that came with the 95 gsr tranny .
I think the one that came on the gsr tranny produces a AC signal and will have to use a different cluster not 100% on that please help
Old Jan 6, 2005 | 07:34 PM
Mr_CRX's Avatar
Default Re: 95 gsr tranny in crx what vss (HELICALB16)
Use the cable one unless you're using a cluster that needs an electronic VSS.
Old Jan 6, 2005 | 07:36 PM
kid-honda's Avatar
Default Re: 95 gsr tranny in crx what vss (Mr_CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr_CRX &raquo;</TD></TR><TR><TD CLASS="quote">Use the cable one unless you're using a cluster that needs an electronic VSS.</TD></TR></TABLE>
Yea you can just remove the electric and replace with the cable.
Old Jan 6, 2005 | 08:15 PM
HELICALB16's Avatar
thank you very much guys i will replace the electric vss with the cable operated vss it should slip right in with no modifications , i hope so .
Thank you
Old Jan 6, 2005 | 08:30 PM
kid-honda's Avatar
Yes it will swap easy.
dannyb18c
May 11, 2012 02:04 PM
crawfo661
12
Oct 22, 2009 04:04 PM
Ldo
Sep 1, 2008 07:20 PM
Zaraki_21
Mar 26, 2006 07:28 AM
wickedEFguy
Dec 16, 2002 03:51 PM
