Q: 99-00 Si cluster on EF
i know this cluster swap has been done and got the how-to for it but my question is what other plugs can i use on the Si cluster ??? it was hard enough to find a Si cluster for cheap but i never found 1 with the plugs. if any1 knows the help would be appreciated so i can do my cluster swap.
*BUMP*
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djprettyrick »</TD></TR><TR><TD CLASS="quote">i got the plugs 40bucks</TD></TR></TABLE>
Sounds a lil steep for them...but thats just my opinion
you can use any 96-00 Civic guage cluster plugs and wiring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkdown »</TD></TR><TR><TD CLASS="quote">check out a u-pull junkyard if you have one in your area. Most places if you can fit it in your pocket its free.</TD></TR></TABLE>
thats called a thief
No, thats actually the policy of the yards around here, figured they were all the same. Even if thats not the case with your local yards, the plugs shouldn't be that expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkdown »</TD></TR><TR><TD CLASS="quote">No, thats actually the policy of the yards around here, figured they were all the same. Even if thats not the case with your local yards, the plugs shouldn't be that expensive.</TD></TR></TABLE>
the policy of the yards is that whatever you can fit in your pocket is free? i am going to call bullshit on that one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr »</TD></TR><TR><TD CLASS="quote">the policy of the yards is that whatever you can fit in your pocket is free? i am going to call bullshit on that one.</TD></TR></TABLE>
Well plugs for that will be free cuz they will fit in my pocket
Plus I already knew that 96-00 plugs will work with the cluster but to be able to find them in a yard around here is like tryin 2 find a needle in a hay stack. I was lucky enough to find a 96 Civic 3 weeks ago but was striped down to the chassis.
You can also use the plugs from a crv. You may also use th eplugs from any 94-01 integra but you will have to repin the plugs so thte wires are in the right places. The actual plastic plug is the same, the wires are just different.
-James-
-James-
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5crx »</TD></TR><TR><TD CLASS="quote">You can also use the plugs from a crv. You may also use th eplugs from any 94-01 integra but you will have to repin the plugs so thte wires are in the right places. The actual plastic plug is the same, the wires are just different.
-James-</TD></TR></TABLE>
Now that I kno i can use others than just the Civic's ill probably have more luck tryin 2 get the plugs. Thanx
LOL thats funny.
LOL thats funny.
I would go for this
I would go for this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djprettyrick »</TD></TR><TR><TD CLASS="quote">i got the plugs 40bucks</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie »</TD></TR><TR><TD CLASS="quote">I would go for this
I would too but 1st i wanna see if i have any luck in findin some in the yard 4 free
thats y i was askin if any other plugs would work other than just the 96-00 Civic's.
</TD></TR></TABLE>I would too but 1st i wanna see if i have any luck in findin some in the yard 4 free
i have an 5 speed cluster from a 98 EX sedan in mine, its a tight fit but it works, i used this one because its blue and matched the car.
my eventual plan is to get an RPM activated switch, and use the SRS light as a shift light inside the cluster. keep it oem
thats mine.
thats mine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_VTEC »</TD></TR><TR><TD CLASS="quote">I never knew that cluster fit. Anyone have any pics of this?? Thanks H-T</TD></TR></TABLE>
heres my write up. All yo uhave to do basicly is swap out the crx plugs for the civic ones and wire up an electric VSS
https://honda-tech.com/zerothread?id=709958
Also Doublethink did you ever buy parts off of me. Do I know you?
-James-
-James-
That's how it works at the u-pull it yard by my house. So I know it's not bullshit. And it's far better than $40.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1990crx »</TD></TR><TR><TD CLASS="quote">That's how it works at the u-pull it yard by my house. So I know it's not bullshit. And it's far better than $40.</TD></TR></TABLE>
well if thats the case, i wish i had that yard by my house. i would wear some big pants.
serously.the pick and pull rips you off most of the time any ways.not on price sbut they always charge the wrong ****.i always steel what ever i can get my hand son from there because they ripped me off so many times i cant even keep track.infact i have a list for my next day off.
1. motor mount bolts
2.tranny mount bolts
3.rear bumper
4.pcv red hose thingy"goes out the bottom through the frame"
5.misc vacume lines from a vw
6.gauge holder clips from a vw.
7.as manny goddamn fuses i can find.
and maybe buy a speaker cover or 2.
3.rear bumper
LMAO. The only thing is, sometimes theycharge a buck to go in. I don't know why sometimes they do and sometimes they don't. But a buck? Why not? I got the factory stereo harness for my CRX off a 93 Civic that way.
lol do they have a sign that says that ? My local pick-n-pull is like that but to an extent. If the part really has no meaning, like clips from electrical circuits the guy will give them to me for free. But lets say I need a door handle, sure it will fit in my pocket but its not free.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx »</TD></TR><TR><TD CLASS="quote">lol do they have a sign that says that ? My local pick-n-pull is like that but to an extent. If the part really has no meaning, like clips from electrical circuits the guy will give them to me for free. But lets say I need a door handle, sure it will fit in my pocket but its not free.</TD></TR></TABLE>
exactly
exactly
